hey please help the noise drives me nuts. its worse when i hit a bump at full lock.
Bushes maybe. Have a look and see if they are cracked.
VT-VZ are very prone to worn out front end bushes. suggest getting them looked at first. Done plenty of them.
I would also suggest checking your ball joints, had a similair noise with my xr8, drove me nuts for ages, wd40'd everything, and then finally bit the bullet and replaced the ball joints. Been right as rain since
thanks guys i ll get it looked at soon
I have a similar thing, only under braking...but not braking in a straight line, only when easing on the breaks going around corners...more exaggerated when going downhill due to more pressure on the front end.
Any idea's on mine?
If it makes the noise while turning it will be the ball joints for sure. Jack it up and shake the wheels from side to side see if there is any movement, if so then it's your balls.
Lol I'm referring to the OP
Yeah i wil jack it up and dude i will brake mate he might of heard off it
