Results 1 to 11 of 11
Thread: L76 heads?
    VZ SS
    Jan 2011
    Default L76 heads?
    Havn an l76 iv hurd i have to change the lifters when i do a cam package so that means heads off would it be worth porting out L76 heads? Im planing on putting boost through it in the future so im not shore if the heads are worth it. Can anyone give me some advice?
    Also should i go diff gears and true track before the cam or cam first? The diff has been rebuilt so shouldnt brake straight away. Any ideas?
    VX L67 S
    Oct 2011
    VZ SS
    Jan 2011
    Wat size heads in cfm would be good for a supercharger? Would biggest be best when goin forced?
    njmartin is offline Banned
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    i wouldn't bother doing the heads for cam only they flow very well from factory!
    maybe down the track when you do boost or if you'd rather do it now while theyre perhaps get them CNC'd by nathan higgins?
    also is your car manual or auto? perhaps a new clutch or bigger stall would be more necessary over diff gears, although both together will compliment the cam very well!
    what size cam are you looking at running?
    VZ SS
    Jan 2011
    The cars a manual still not shore on 4.11s or 3.9s and i think the cam specs are 225/237. Is the anyone in w.a that ports ls heads?
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    definitely go for 4.11's with the manual. although if you do plan on going boosted it will no doubt be a bit much!
    new clutch would be ideal before the cam though as the stock one won't hold up very well with the new power and torque!
    get in contact with active auto or wa performance, some workshops do exchange higgins heads, but as I already mentioned they flow very well in stock form!
    whos going to be doing the work?
    VZ SS
    Jan 2011
    Proble me as i am a mechanic just havnt got into the ls engines yet still learning. The car already has a aftermarket clutch its not the best but still better then standed. Just out of intreast y do u recomend 4.11s
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    fair enough then the clutch may be able too hold up for a while longer then..
    why 4.11's? there going too give you the best improvement, and you can cruise along in 6th at 110 and your revs will sit relatively low.. no real reason to go with 3.9's you may aswell make the most out of what you're doing..
    VZ SS
    Jan 2011
    4.11s is the way to go because if i go 3.9s ill prob be disappointed and iv stopped doing long trips every weekend so fuel wont matter as much. Will do diff then a decent clutch so its all good for when the cam goes in. Those ideas will prob be different by tomorrow
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    thats it mate youll do 3.9's be happy as for a few weeks, then think f*ck i should've gone 4.11's...
    sounds like a good plan of attack, but i know what you mean change of plans by tomorrow, keep us posted anyway bud
    good luck...
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I'd be getting a boost friendly cam if you're seriously considering supercharging.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  1. [Ecotec] So I have heads and a cam going in...
    By one_and_only2004 in forum V6 Development And Modification
    Last Post: 14-07-2010, 06:46 AM
  2. [TAS] wtb v8 vt heads
    By vyjess in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2010, 09:07 PM
  3. Vn Efi V8 Heads
    By VL2Di4 in forum Parts And Other Items For Sale
    Last Post: 06-01-2007, 12:55 PM
  4. Which Heads
    By chappy in forum General
    Last Post: 17-12-2006, 11:50 PM
