Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By gslrallysport
Thread: HSV 6.0L brake surge
    VZ SS
    Nov 2011
    wanneroo
    Default HSV 6.0L brake surge
    Hi,
    Just seeing if there is any brake guns on here that could give me some helpful advice, I have a VZ SS, its a LS1 but has upgraded brakes to the HSV 6.0 liter brakes with slotted rotors, I have had both front and rear skimmed on separate occasions in the last couple months, rear where only done about three weeks ago, front about a month before that and probably a month before that again, Now the front discs are sending a surge to the steering wheel when braking lightly at around 60 KMPH again, not sure what to try next as the longer I leave it the more damage it does to the bushes etc in the front end, anyone else had this problem?
    VZ AWD One Tonner
    Jul 2006
    3 Questions:
    - What pads are you running?
    - How were they bed in after the rotors were machined?
    And most importantly....
    - When where the wheel bearings checked last?
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VZ SS
    Nov 2011
    wanneroo
    Thanks for the reply,
    Pads- not sure but will find out Monday but I can say there chunky and messy as in they keep the mags dirty.
    Bed in? Ill have to ask about that too
    With the wheel bearings, not sure what is involved in checking them, would you need to dismantle the hub? Or could you do it just by jacking the wheel off the ground and checking for any excess movement? The car has only done 60'000 KMS.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    I have found that as the brakes have gotten bigger over the years so has this very problem seemed to become more common after machining.
    Maybe because the large rotors are quite heavy in std form the machinist isn't getting it on the machine perfectly straight.
    I personally know of 2 cases where guys did a pad change (same new pads as what they took out) with a rotor machine and ended up with surging at low speeds, throbbing as one guy put it.
    Anyway they checked everything they could at home like did the wheels lose any weights, did the hubs look and feel good, were the hub mating surfaces all clean, even used a gauge to measure run out on the discs, all seemed good but still throbbed.
    Both bit the bullet and put new discs on, one with DBA5000 discs and aluminium hubs and the other RDA's both with no more throbbing.
    My money goes on machining of the discs as the cause.
    But as GSRally said, were they beddded in properly although these days not many people know you should or even know how to bed in brakes and doesn't seem to be a major problem among the masses.
    So my
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VZ SS
    Nov 2011
    wanneroo
    Got quoted a EST $2000 today for front disk and pad replacement, that's with the two piece rotors, they said the size was a bit larger because they are Skaife specials, possibly from this car.
    Holden Special Vehicles Senator Skaife Signature Z Car Research - CarPoint Australia
    How does that price sound? Pretty keen to get it fixed...
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    Quote Originally Posted by Brenah View Post
    $2000??? Serious
    Are they Brembo"s or something? That's steep.
    B
    thats cheap for brakes, more serious kits start from 5-10k
    VZ Exec Wagon
    Apr 2009
    Manly, NSW
    What rotors and pads?
    Are you talking about a FULL brake package? Well yeah $2000 is cheap. But the OP is after rotors and pads only.
    Correct me if im wrong
    B
    VZ SS
    Nov 2011
    wanneroo
    Its just for the replacement of the front pads and rotors with a pad specifically for street use, heavy duty pads that have been tweaked for street use with out the squeal, the rotors are the premo ones, two piece, cant remember the brand, RDA or something, they are getting more available options tomorrow so should get some more feed back, the two piece rotors sound appealing though, this seems to be a common thing
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by dijm8 View Post
    But he is only talking pads and rotors for front replacement, not a whole new brake kit.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by VZSS View Post
    They won't be RDA as RDA don't do two piece rotors. They'll be DBA 5000 Series slotted, which even our price is $627 per rotor, so yes, they're expensive suckers! Pads I'd go QFM HPX, which are a Bendix Ultimate equivalent, but low dust and rotor wear, $119 for the set. So all up for a pair of DBA 5000 Series two piece rotors, and a set of pads, $1373.
    Otherwise RDA do make a single piece rotor replacement for the front, which are $559 for the pair in slotted.
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Quote Originally Posted by Surfwagon View Post
    my bad...thats expensive then
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    You're right it is expensive for front only even though it is for top of the line 2 piece rotors not like GSL's price of $1373 incl quality pads.
    Also it appears the OP has VZ Ap's fitted to the car which is a good street setup for VT-VZ's.
    I will be looking 2 piece rotors when my AP brakes need pads and/or rotors.
    VZ SS
    Nov 2011
    wanneroo
    Quote Originally Posted by gslrallysport View Post
    Would you know if RDA have them in this size?
    http://dba.com.au/products/DBA52018BLKSL
  15. #15
    VZ AWD One Tonner
    Jul 2006
    Not as a two piece rotor they don't, but as a single piece slotted rotor, unpainted, they're $559 for the pair.
  1. [SA] Ase surge tank
    By Mayhem05 in forum Parts And Other Items For Sale
    Last Post: 21-08-2011, 05:18 AM
  2. [NSW] Under car surge tank
    By cuckoo in forum Parts And Other Items For Sale
    Last Post: 28-05-2011, 05:31 PM
  3. why does my car surge?
    By HSV472 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2009, 02:52 AM
  4. [Ecotec] surge tank help
    By p_schrapel in forum V6 Development And Modification
    Last Post: 13-05-2009, 11:09 AM
  5. VK EFI - Rev Surge Problem
    By darkmoon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-01-2009, 04:02 PM
Tags for this Thread
