Results 1 to 6 of 6
Thread: Transmission playing up in my sv6
    Vz sv6 '04'
    Nov 2011
    Default Transmission playing up in my sv6
    Hey guys just wondering if anyone can help me out....?
    I have a 04 vz sv6 with transmission problems. When I select drive its like my car is in neutral and when I
    select reverse same thing. my car has only done 93,000 klms. Mind u I serviced trannie about 5 months ago
    Has anyone had same problem?
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I had exactly the same problem and was stuck in my works car park for about 3 hours, waiting for a family member as my NRMA membership payment didn't come out .
    Either way, i ended up getting the transmission serviced and then a new radiator (as the tranny cooler is on the radiator, which was blocked) and then the issues went away completely for about.. 2 weeks.. then they've come back.. i can now drive my car ok, but i can't reverse on any hills (just revs revs).
    First thing most other people suggest, check fluid levels.
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Check your fluids, if they are at the correct level there is a good chance your tranny oil pump has failed. This just happened to me a month ago. $2500 for a rebuild. Also these gearboxes are prove to losing reverse altogether, there is quite a bit of info about this issue on the net.
    VZ Executive
    Oct 2011
    is there any way you can check yourself at home if the transmission cooler is blocked
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    replace it for aftermarket, youd be doing yourself a favour anyway
    Life starts at 200km/h
  1. T5 is playing up
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2011, 09:02 AM
  2. Playing up VS.
    By Wombles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2011, 06:26 PM
  3. Playing with the LAW!
    By mainpath in forum The Pub
    Last Post: 17-08-2010, 08:07 PM
  4. Help car is playing up
    By Holden Chick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2008, 05:48 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
