Results 1 to 15 of 15
Thread: Yet another'check powertrain' - Misfiring thread for VZ commodore -
    Vzniko Guest
    Angry Yet another'check powertrain' - Misfiring thread for VZ commodore -
    Firstly,
    allow me to apologise to the moderators as there are at least 3 threads that talk about the same problem I am experiencing.
    The reason I started the new thread is to share with others what I have done so far about the problem and where I am today.
    I had the misfiring/check power train errors since I bought the damn thing back in 2008 with 63000K on the clock. (A small note here, I will never buy anything with a Holden badge on it as long as I live).
    It is now 2011 and after hundreds of dollars short I am back to where I started, the fault has come up again today and I feel like
    driving the car into a tree and be done with it. Seriously I am so mad at Holden right now (But I guess this is not the focus of the topic here).
    To make long story short, I have taken it to many workshops, including a holden dealer and the last time even a performance tuning workshop
    that specialises on Commodores and Falcons.
    I have so far attempted:
    2008 - Holden dealer Code P0460 - Carried out TL1164-0608 and reprogrammed ECU - send me on my way - No charge under warranty
    2009 - Holden dealer Code 33 - Cleared - $55
    2010 - Fuel pump change (Not sure if that was related to this problem $155)
    2011 - Fault codes P0300 (Mylticylinder misfire) and P0303 (Cylinder misfire 3) - cleared fault - $55 - Midas
    2011 - The very next day!! Unkown error - replaced spark plugs and inlet manifold gasket - $300
    2011 - Performance tuning workshop - Replaced coil pack - $175
    These date do not include parts I have replaced myself including leads and another set of spark-plugs.
    Now here I am, error came up again the other day. Is there a Holden representative that can come into this forum and shed some light?
    I do not believe this is rocket science, any good mechanic with experience and know-how should be able to fix this right??
    One note, out of all the places I went for the problem to be fixed, the MOST hopeless ones were the Holden Dealer, who did not even
    bother to replace anything (I guess they saved me money which can be a good thing), cleared the fault in a hurry and send me home!
    Clearing the fault will not fix the problem, why would I have to pay $55 each time to do that?
    Does anyone have a definite solution here or do I drive the car off a cliff and be done with it?
    REGARDS
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    You never said if it actually missfires or not, is it only codes or physical symptoms?
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    impulsive's Avatar
    impulsive is online now Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Vzniko View Post
    These are very expensive bills!!
    spark plugs for 6 cost me $45 and the inlet gasket is about $20, not even an houris work, $150 max... $65 if you DIY
    Replaced a coil pack for $165??? Rip off..
    Possible solution, injectors...
    Life starts at 200km/h
    Vzniko Guest
    I agree, I shouldn't have let them changed the spark plugs should have done it myself...
    With all the physicals symptoms are all there, you name it, revs not idling properly, Car no accelerating as its suppose to, and also now there is a new one,
    the car will shut down and that small symbol on the bottom right hand corner will come on (Check emission system) Which has never happened before.
    Also I have replaced injector 2 i remember, it was done under warranty, so yeah had tried that as well, Any ideas?
    I am thinking of replacing the leads never done that before since I bought the car.
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    is there any smoke coming from your exhaust?
    the hose that goes into your intake pipe, does that have smoke coming out of it?
    Vzniko Guest
    Default Coil packs
    Hey guys,
    Took it to another guy today. Said that the coil packs are usually what's causing it as it is a common fault with the vz.
    The problem is that the other mechanic replaced only one coil pack, which I was told its stupid. Once you do them, you do them all.
    I had misfiring on cylinder 1,2 and 6.
    So anyone know on how to change them? Any guides at all? Because I was told they are quite expensive for a whole set (Around $150 each) not including labour.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Air intake duct off
    6 13mm bolts to undo inlet manifold
    Take TB connectors off and all hoses on the manifold.
    Split the manifold upper section by lifting it upwards. You'll likely have the revised metal gasket as you've had the manifold off before.
    You dont need to totally remove the manifold, it can just be lifted and blocked up with a hammer handle or piece of wood.
    Disconnect the connectors
    Undo 10mm bolt
    Lift out coilpack.
    Refit is just reverse of above.
    I dont completely agree with the "change one, change all" principal
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Vzniko Guest
    Hello,
    Thank you for the isntructions. Got my self 6 coil packs for $50 each from my local repco.
    Job was all done.
    Well the principle of change one, change all is probably due to the multicylinder misfire. I had misfiring in cylinder 1,3 and 6.
    I just changed them, took it for a drive and everything looks ok so far.
    I will keep you posted.
    Thanks everyone for your help
    6Speed Manual VZ SV6
    Nov 2011
    Aubin Grove, Perth
    Hi Vzniko, in this past week I have had the exact same probs with my 2005 VZ SV6, 86,000ks. It started with one of my coil packs melting in half!!! The diagnosis was injectors, and then electrics, replaced gasket, and now powertrain fault. We also have to change my timing chains because it sounds like someone in my engine has a metal ladder banging on the sides, stops after 2 seconds. My car is chewing fuel and just running sh!t. My partner will bring home 6 new coil packs tomorrow and we will try this now.... thanks alot for your experience, hope all worked out for you?????
    Vzniko Guest
    Quote Originally Posted by Holden1990 View Post
    Not exactly - Make sure you get new spark plugs as well - apparently damaged coil packs will damage the spark plugs with them.
    I only change the coil packs - and I after 3 days of no problems, the shaking/rough idling has come back - I will take out spark plugs and clean them -It better be the spark plugs - ITS DRIVING ME NUTS.
    I tested (with a multimeter) my old and new coil packs and I came up with some interesting values
    Anyone with a repair manual that can have the look on the values (in Ohms) for the VZ coils.??
    Here is how i tested, however all of them are giving me different readings.
    I just replaced all 6 of them. It has 4 metal pins I tested the 2 middle ones first and then the left (1st) and 3rd one. (The other combinations gave me no reading).
    OLD COILS - in MEGA ohms
    pin tested XxXx (1st and 3rd) ---- Two middle pins xXXx
    1 - 5.22 -------------------------- 11.94
    2 - 5.00 -------------------------- 11.78
    3 - 0.46 ---------------------------No reading (This one is finished)
    4 - 5.02 ---------------------------11.87
    5 - 5.05 ---------------------------11.92
    BRAND NEW COILS
    1 - 10.00------------------------- 16.05
    2 - 08.57 ------------------------17.33
    3 - 11.96 ------------------------13.05
    4 - 08.71 ------------------------16.55
    5 - 08.00 ------------------------15.37
    6 - 08.21 ------------------------16.14
    As you can see the values are ALL over the place, however I deducted that the two middle pins need to be 13+
    and the 1st-3rd pin more than 10+
    Anyone that can give me some values to work with??
    Vzniko Guest
    I only changed the coil packs - and after 2-3 days of no problems, the shaking/rough idling has come back - I will take out spark plugs and clean them -It better be the spark plugs - ITS DRIVING ME NUTS.
    pin tested XxXx (1st and 3rd) Two middle pins xXXx
    1 - 5.22 11.94
    2 - 5.00 11.78
    3 - 0.46 No reading (This one is finished)
    4 - 5.02 11.87
    5 - 5.05 11.92
    BRAND NEW COILS
    1 - 10.00 16.05
    2 - 08.57 17.33
    3 - 11.96 13.05
    4 - 08.71 16.55
    5 - 08.00 15.37
    6 - 08.21 16.14
    VZ
    Dec 2011
    Default same prob
    Hi
    I am a chick who dosnt want to be ripped off by a mechanic, I have a 2006 VZ and twice now with air con on and accelerating away from an intersection, I have lost power and the car started shuddering and "check power train" alarm has flashed at me, after turning car off and restarting it seemed fine? My car has nearly done 200,000 kms, just had a service. So from the above threads, Do you think my coils are going? if yes do I need to get it fixed ASAP and where do I take it to get fixed? Im in North East of Adelaide, can anyone help me with some advice? Also seems to be chewing petrol and aircon is using alot of power.....
    VZ
    Dec 2011
    Since posting the above, my VZ is now screwed, alarm constantly going off "check powertrain" and is chugging and shuddering and hasnt much power, got it home and not moving it now, merry xmas to me!!! Please give me som advice so Im not ripped off again at the mechanics..
    Mar 2008
    Mate I rember you posting in my thread, you never mentioned you had three cyl misfiring.
    The first thing to check is for a vacuum leak specially if it is multi/random misfires, there are many videos on you tube on how to do this but it can be dangerous because you are spraying flammable liquid on a running engine, so you should take it to a mechanic
    for this, theyll find it too as they have done this before.
    Also check the wiring back to the ecm, I went through all the pain you did but without $$$ I did it all myself. I run out of options and took it to the mechanic who checked the wiring and traced the fault back to the ecm. $900 part plus labour 2hrs.
    by the way I rang holden and asked the mechanic if he has seen this alot an he mentioned they go all the time on the vz's 2005 models not sure about the later vz's.
    After the new one was installed there was still a rough idle so I cleaned the air intake pipe and maf sensor and now its silent at idle.
    Good Luck
  15. #15
    Vzniko Guest
    elshonno,
    Thanks a lot man - Could not find my thread on the forums since it has been so long -
    To this day Since I had posted this thread, I had not fixed the problem. (had the car unregistered sitting in the garage for like 3 months coz it got so bad it was un-driveable).
    have replaced all coil packs and brand new spark plugs still no solution.
    I did a compression check today - all pressures normal - so that eliminates faulty internals valves, valve seals, valve springs etc
    I am starting to think it is an electronic issue too (Oh missed those days where cars had no electronics).
    MIA - Sorry for such a late reply I couldnt find my thread I thought It got deleted.
    I am not sure on what you can do yourself, but buying a new set of spark plugs would be good - when was the last time you changed them?
  1. Replies: 2
    Last Post: 29-07-2011, 10:54 PM
  2. Vr Commodore Misfiring problem
    By Thunder Child in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2011, 01:45 PM
  3. The Official VE Commodore FACTS Thread
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-07-2006, 03:04 PM
