Questions have been raised about how i have my catch can plumbed. What are your thoughts. Car in question is a 2005 VZ Alloytec 190kw with 140,000 km on the clock.
My setup
Both 'ports' on the rocker cover's have been plumbed into a T piece then that goes into the lower port on the catch can. The other port is plumbed into the intake pipe after the maf.
Possible Issues
The Passenger rocker cover is a 'breather' so i have been told.. and, should be plumbed into the intake pipe. In a perfect motor, with no 'blow-by', there wouldnt be a requirement for a catch can anyway. Blowby would be occuring from this 'breather'. The other side or drivers side is a PCV where the gases are emitted, etc etc.. this is supoosed to be plumbed into the occ, and has been. No issue there.
I have both outlets on the intake manifold connected to each other.
anyway, how would you connect a catch can to an alloytec, without boost.
Life starts at 200km/h
