just wondering if anyone knows how to change the auto trans fluid in 05 vz sv6
there is a fill plug on side of trans and a drain plug in pan. you can also buy a filter kit from holden, which requires the pan to be removed. The last one i did i drained and changed the filter. put the new oil through the filler hole ( i think its on passenger side rear of trans). fill it up until the fluid comes out of hole. start engine, let idle for a short period. engine off. top up tans fluid again. I then start engine and top up the fluid again, this just puts a little more fluid into trans. All this must be done when trans cold.
