hey, is it possible to fit an all alloy radiator for an ls1 in the sv6? obviously with custom hoses to and from the radiator.
cheers
actually just checked, hoses are on completely different sides of the radiator. mods delete please
They are the same all the pics on eBay are upside down I have a ls2 and and alloytech and the the outlets are in the same spot
Sorry for sounding stupid, whats the difference between the LS1 radiator and standard SV6 alloytec?
I was more thinking that if they are similar, putting in an all alloy radiator. I don't think you can buy an alloy radiator for the sv6.
If you have the coin PWR Performance make them.
you would need a to make sure its from a vz ls1 or ls2 for it to fit as as vt-vy ls1 radiators had the top hose at the top not half way down
they only issue is you will have 2 radiator caps
So what's the go with this radiator, why so you want it so bad, what's wrong with standard?
Originally Posted by Little Red VZ Go-Kart
1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??Originally Posted by HoldenV8
give everything a spray with wd40 wheels brakes that should fix the squeaks
