Results 1 to 10 of 10
Thread: Power window relay click sound from BCM
    VZ MY06 SS
    Aug 2008
    Exclamation Power window relay click sound from BCM
    Hey fellas recently when I raise my front power windows they almost get to the top and there is a clicking sound (like a relay) coming from somewhere under the steering wheel. Have checked to see it is not the window relay. sounds like it is coming from the BCM.
    Anyone got any ideas? I thought that the BCM was all transistorised - as in no relays.
    This is starting to give me the sh*ts so any help would be greatly appreciated.
    Am happy to help you guys out if I can ever help!
    SS Thunder 06
    Dec 2011
    perth
    The BCM does have an assortment of relays in it mate nothing to worry about
    VZ MY06 SS
    Aug 2008
    Quote Originally Posted by VZSSTHUNDER06 View Post
    ahh, cool. Can they be accessed? One sounds like it needs to be replaced
    VZ MY06 SS
    Aug 2008
    yeah but it sounds like sh*t
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    Quote Originally Posted by derrro View Post
    This sounds suspiciously like the power window circuit breaker tripping under load, especially when you have said that it occurs when the window is nearly to the top & with the window motor at a higher load. The circuit breaker is located on the instrument panel fuse block which is in the vicinity of the BCM, so the clicking sound may sound like it is coming from the BCM.
    VZ MY06 SS
    Aug 2008
    Quote Originally Posted by bcw61 View Post
    Checked the relay there - thanks for mentioning it but unfortunately it aint that one
    Sep 2009
    Not the relay mate. There is a circuit breaker for the power windows (does the similar job to a fuse). That is what I was referring to.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    It is normal for relays to "click" though it shouldnt be audible in the cab.
    Silver Certified.
    VZ MY06 SS
    Aug 2008
    Yeah I know, but this one clicks about 3 times a second if you hold the switch in the top position. Have not yet looked closely into it but have felt the outside of the BCM when happening; it feels like it is something in there
    VZ MY06 SS
    Aug 2008
    Cheers must have misunderstood u. I have studied the circuitry diagram pretty closely on the fuse/relay panel. I can't see a circuit breaker on there, just fuses and relays. And say a circuit breaker was tripping, wouldn't it remain off after it had tripped? What's the circuit breaker look like? Thanks
  1. VS ECU.. Makes a click' sound every few min. :S
    By Dum*P*ster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2011, 06:25 PM
  2. Power window relay
    By MEESEN in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-08-2011, 11:50 PM
  3. Clicking noise from drives side power window relay
    By NetWizzard in forum Electrical Wiring / Questions
    Last Post: 05-02-2011, 03:48 AM
  4. Power Window (Just 1) Seized up. Clicking sound from inside dash.
    By MikesVT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-01-2007, 05:21 PM
  5. Click Sound in ECU??
    By Ronaldw in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-12-2005, 10:59 AM
