Results 1 to 9 of 9
Thread: VZ SV6 Removal of Raspy Exhaust sound
    VZ SV6
    Nov 2011
    Hobart
    Default VZ SV6 Removal of Raspy Exhaust sound
    Hi Guys,
    I have pacemaker extractors and just running a 2.5" pipe after the 2 resonators... sound like a V8 but has a raspy noise when you give it to her, any ideas to resolve this whilst trying to keep it sounding similar to a V8 without making it quiet. I have euro 3 cats, Reading Alot and hearing from exhaust specialists i believe high flow cats wouldn't have been that great plus adding alot more of a raspy horrid sound,
    maybe another resonator? or small muffler? any thoughts? i was also told the raspy sound is from the cats being moved forward under the car but couldn't do much about that as the originals were too big
    cheers Toby
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The only way to stop that awful raspy note is to keep the cats in the original position and keep the two original resonators that are under the front. Some extractors require the cats to be moved back and aftermarket ones fitted, this will make the exhaust note raspy.
    Not much you can do I'm afraid, you can try a big resonator on the rear, it will deepen the note but will also make it a bit quieter.
    Visit my Facebook page
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Does it have to sound like a v8? Everyone knows its a v6 because of the badges.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Quote Originally Posted by CRUSTIN View Post
    More importantly you will never get a true V8 sound out of a V6 anyway. V6's can sound great in their own right, getting rid of the raspiness of the alloytec goes a long way to getting a real nice sound out of them. My exhaust has zero rasp, no drone and sounds brilliant under load at WOT. CHE FTW!!!
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
    VZ SV6
    Nov 2011
    Hobart
    It is somewhat debadged, none the less obviously its not a v8 but it sounds mean and thats the sound i'm hoping to keep, everyone has different prefferences of what they believe sounds good and what doesn't, but it sounds good for a v6 just wanting to get rid of the raspy sound, although its not as bad as some ive heard, on a positive it has no drone lol,
    torana how much difference did you notice with the vcm tune and diff gears? and what sort of prices were you paying for them?
    cheers
    VZ S 175 Ute
    Nov 2010
    Personally I love the rough raspy crude note.
    Mar 2009
    Quote Originally Posted by IMPULSIVE VZSV6 View Post
    cheers
    I had the tune done first, it made a big difference especially down low though to the midrange as most of the torque management is removed. The diff gears made an even bigger difference, Best mod ive done to the car by a long shot. The car now does the 0-100 in about 6.8 seconds. The tune was $880 and the diff gears were $1000 including a full rebuild of the diff.
    More mods to come
    VZ SV6
    Nov 2011
    Hobart
    Sounds like new diff gears are the best $1000 you could spend on an sv6 something il definatley look at getting done once my wallet fills itself back up again!
    Mar 2009
    Less then $1000 if you just get the gears changed without rebuilding the diff.
    More mods to come
  1. 2.5' exhaust sounding raspy at around 3000rpm
    By hoofelmuma in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2011, 11:07 PM
  2. VR V6 Exhaust manifold removal help
    By BONSVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2009, 08:28 PM
  3. Exhaust / Mould removal
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2008, 06:23 AM
  4. Sound system removal??
    By Phreddy in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-01-2007, 07:35 PM
  5. VC Exhaust removal
    By vcstraightsix in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-08-2005, 02:53 PM
