Results 1 to 7 of 7
Thread: Anyone taken out the rear seats?!?!!
    VZ Executive
    Aug 2009
    Default Anyone taken out the rear seats?!?!!
    I've been trying on and off for at least a year now, and still no luck. I want to take the rear seats out so I can put some seat covers on, but the most I ever get to is lifting it up a bit after pulling on the tables underneath the seats. It seems that the back portion of the seats (the part where your back rests on) needs to come out first, and they don't look like they budge at all.
    So, anyone ever successfully taken out the rear seats?
    Barbados Mica VZ Calais
    Feb 2011
    Melbourne, AUS
    The bottom part of the seat doesn't require you to remove the back part. All you have to do is pull outwards on the two tables underneath (making sure they have actually unclipped) and pull up from the bottom right next to each table. Seat should come out almost without any great force. Took me about 5 mins the first time i tried. Goodluck.
    VZ Executive
    Aug 2009
    Thanks mate. Did someone give you a hand as well, or did you do it yourself? Maybe I am getting the unclipping of the tabs wrong. When I pull the tab, the seat jolts up a bit and that's when I start trying to remove the seat to no avail. Maybe I have to pull more on the clip?
    (I am afraid of breaking something).
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    There is one clip on either side...did you get both? Pull one tab and lift the seat, go around to the other side, pull that sides tab and lift the seat again, then pull it forward to get the buckles out of the seat.
    Once you've done that there are two 13mm bolts (one for each side) for the back sections. Undo those and then lift each back section up. They are independent of each other.
    Let us know how you go
    Feb 2011
    Melbourne, AUS
    Quote Originally Posted by toey View Post
    Nah did it myself. Just make sure you have unclipped them on both sides and just pull the seat up from both sides.
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I've had to use some serious force with the 2 tabs on the lower part of the seat.
    Turned out, this was cause mine were broken.
    Anyone know where you can get the tab/clips from?
    VZ MY06 SS
    Aug 2008
    Quote Originally Posted by morphix View Post
    You could try a wrecker like picknpayless or the one on Northern Rd in Londonderry. Or any wrecker, or buy em new from Holden. Maybe Fleabay too
  1. gto rear seats
    By HSVSENATORVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-11-2011, 11:11 PM
  2. [VIC] WTB vr-vs hsv front seats and possibly rear seats aswell
    By YILDI2 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-12-2010, 09:54 PM
  3. [NSW] VS rear seats $10
    By maldotcom2 in forum Parts And Other Items For Sale
    Last Post: 04-01-2010, 10:41 AM
  4. VS rear seats
    By AussiePride in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2009, 01:35 PM
  5. Rear Seats QLD LAW + Interchangeable Seats
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-03-2009, 08:30 PM
