Results 1 to 6 of 6
Thread: VZ SS 6.0L GearBox Problem..
    SS Thunder 06
    Dec 2011
    perth
    Default VZ SS 6.0L GearBox Problem..
    I just purchased a VZ Thunder and some times the gears will grind when changing, when going into first & reverse from start and also sometimes when u let out the clutch after a up or down change, also it
    sometimes doesnt let you go into a gear during a up or down change and i have to keep trying different gears before one lets me go into
    can anyone put me in the right direction :S
    VE SSV MY10
    Jun 2006
    Try bleeding the clutch up and replacing the fluid in the gear box mine was like that when I got it just remember the gear box runs auto trans fluid and takes 4-5 liters from memory
    SS Thunder 06
    Dec 2011
    perth
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    remember to fill the box from the hole the reverse sensor screws into ( drivers side )
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VZ MY06 SS
    Aug 2008
    Quote Originally Posted by dirt drifter View Post
    Or raise the passenger side w/out raising driver side and fill thru the fill hole till it comes out
    VE SSV MY10
    Jun 2006
    +1 for raising passenger side thats how i did mine
  1. vn gearbox problem
    By blom27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2009, 10:37 AM
  2. gearbox problem
    By iRiot in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2009, 11:49 PM
  3. gearbox problem
    By MajorDoofDoof in forum General
    Last Post: 08-09-2008, 03:26 PM
  4. gearbox problem??
    By ratz26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2008, 07:29 AM
  5. Gearbox Problem
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2005, 10:23 AM
Tags for this Thread
