hi guys, came home last night turned car off, tried to start this morning but ignition will not bud ge from the locke d position,igni tion h as been sticky for few days, is there any trick to getting ignition to turn other than removel and renew.
what we have here,is a failure too communicate!!
Put the key in.
Open palm give it a good solid tap on the end. If you can get some graphite dust into it first would be good.
Whilst that might get it started, it is time to start looking for a new lock barrel. They can be bought at any spare parts place & a locksmith should be able to help re-key it, so your old keys work.
Read here:-
ignition barrel wont turn
Unfortunately mate.... that's the first sign of she's knackered.
Same thing happened to me a couple months back (at the Kmart in Pirie coincidentally.)
If you're in the RAA, or know someone who is, the RAA Pirie crew know how to get her going in no time.
I was lucky enough that Spencer motors could replace the barrel (and key match) that same afternoon, all up it was around $250.
peter page holden,are doing mine friday,$225;00
Pull your old ignition out, buy the new one from Holden, and fit the new pins into the new ignition in the same order as the old one.
Do it yourself and save $200.
Best way to unjam it is tap the end of the key with the handle of a screwdriver or very small hammer while applying turning pressure with the other hand.
Dont put anything into the barrel it can make it worse. Just replace it.
Silver Certified.
well RiCey, that's exactly what i did next day after letting barrle soak in wd 40 overnight, tap, turn, came loose,car would not start, turns over but no go,sceen comes up with service vehicle soon,i have to turn key 4 times before it will try to start,put new barrel and swith on rear of barrel housing,exacly the same thing happening,any idea's anyone
Is the slip ring contacting the key properly?
Silver Certified.
no it won't fit the new barrel, but i can start car if i if i press unlock twice,and that is without the key touching the slip ring,must the key contact the ring?
If the ring doesnt fit its the wrong barrel.
Yes it should contact the ring to disarm the immobiliser.
Silver Certified.
yes RiCeY, i know ithe barrel must be wrong even though it fits in the housing and starts the car the key reader won't fit.
got to get the other first.looks like needing special tool to get cowling off.
please email me on allvikk@yahoo.com.au re location etc.
Had the same issue not long ago. Locksmith wanted $350 to come out and replace the barrel.
Go down to Repco, buy an ignition barrel - P/No. NIB74, about $60.00 retail, take it to a locksmith who should charge about $30 to rekey it. Pretty easy to remove/install new barrel yourself.
Ben.
