Results 1 to 18 of 18
Thread: Towbar Bolts and Wiring Harness
    Black VZ Wagon
    Apr 2008
    Brishole QLD. Hopefully Gold Coast soon
    Default Towbar Bolts and Wiring Harness
    Hey guys,
    recently picked up a second hand towbar to suit a VZ wagon, bar is in awesome condition, just didn't come with any bolts. I was wondering if anyone knows the type of bolts needed for a factory 1200kg bar?? also i take it there is 6 bolts needed??
    Also i've heard that with the wiring harness if i get a genuine one from holden it should all just be plug and play with the harness under the carpet?? no cutting/splicing of wires needed. Is this true?
    Thanks in advance!
    VE SSV MY10
    Jun 2006
    Pay a tow bar place to fit it correctly covers your arse if some thing went wrong harness is plug and play u can do that your self
    VZ Wagon
    Jun 2011
    Brisbane North
    Quote Originally Posted by illlusion View Post
    To Illusion, I would be very surprised if any tow bar fitter will cover a second hand bar.
    Weekend Warrior, Too long ago since I fitted mine to tell you what bolts and nuts required but in relation to wiring harness, yes, factory one is plug and play although I do remember having to make a hole for the wiring to go through the rear panel behind the bar so I could feed it into the drivers rear tail light area.
    Black VZ Wagon
    Apr 2008
    Thanks for the reply! And yeah I'm not too worried about making a hole for the harness to go through, just want to make sure I buy the right bolts!! Cheers
    white vz 2006
    Nov 2009
    Default tow bar fitting
    on sedan you use existing bolts would think it would be same on wagon wiring is plug in and it is done.
    Black VZ Wagon
    Apr 2008
    Ahhh interesting!! So the bolts are already in there hey! Are they just sitting in there or they holding something else up as well? Also does anyone know how many newtons they should be tightened too??
    Cheers!
    white vz 2006
    Nov 2009
    Default tow bar bolts
    the bolts hold on the existing crash bar that you will need to remove to put your tow bar behind then tighten as much as you can as they are big bolts and you wont break or strip them
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Depends on the brand of towbar though. Some have two brackets that bolt to the car, then the main bar bolts to those, in which case you will need bolts. Any bolt will do, just get new ones. Old ones will have stretched.
    Visit my Facebook page
    Black VZ Wagon
    Apr 2008
    It's a genuine Holden 1200kg one, appears to have 6 places for bolts, 2 at either end an two in the middle. Sound right?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The two at either end will pick up on the existing bolts that hold the intrusion bar to the body behind the bumper. The towbar replaces this bar. The other two will have to be drilled from memory and new bolts fitted. Did it come with the plate that goes inside the boot behind the two bolt positions in the middle of the bar?
    white vz 2006
    Nov 2009
    exactly the same as my one i fitted use original bolts out of the crash bars and also refit crash bars
    Black VZ Wagon
    Apr 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I'm not too sure mate, only saw it briefly before I went to work this morning, I'll get some photos and post tthem when I get home.
    Whitevz, so you refitted the crash bar as well as the towbar ?
    white vz 2006
    Nov 2009
    Black VZ Wagon
    Apr 2008
    Well just finished fitting the towbar!!! wasn't hard at all, only took a little over an hour and i didn't really know what i was doing. it's now on and ready to #### someones shins up! (probably mine)
    Im picking up the wiring harness from holden on sat, from what i hear it's meant to be plug and play but i cant for the life of me see where it plugs into!? There is a black cord with wires exposed that look like it's been cut.... really hoping this isnt it!? as seen in pics below
  15. #15
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Weekend Warrior View Post
    ... it's now on and ready to #### someones shins up! (probably mine)
    hahaha
    its funny cuz its true... how many times have i done it to myself aswell lol
    Life starts at 200km/h
  16. #16
    VE SSV MY10
    Jun 2006
    From memory u unplug the drivers side tail light harness and it has a piggyback plug to refit Back on to the tail lights
  17. #17
    VY SS
    May 2011
    Auckland
    Yeah and there's an extra little blue wire on the right side which is the left hand indicator.
  18. #18
    VZ 2005 Executive Wagon
    Sep 2009
    Northern suburbs of Adelaide
    At a minimum, I would use correctly sized high tensile steel bolts and the appropriate washers. For the cost, they would provide a safety margin, with one less thing to worry about.
  1. Towbar wiring harness?
    By mxb in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-11-2011, 03:27 PM
  2. Installing towbar wiring harness
    By Tylersdad in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2010, 06:47 PM
  3. towbar wiring harness
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-02-2007, 08:15 PM
  4. VX towbar wiring harness with 7 pin flat plug
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2005, 09:00 PM
  5. Towbar Wiring Harness part number..
    By Hairy Eater in forum General
    Last Post: 27-11-2005, 10:34 AM
