Results 1 to 2 of 2
Thread: Blower Fan runs with ignition off, engine runs hot when stationary
    06 SVZ Wagon
    Dec 2011
    Exclamation Blower Fan runs with ignition off, engine runs hot when stationary
    Hi All,
    My (wifes) SVZ wagon has a new noise. It's the sound of the cabin blower fan running flat out regardless of fan switch setting, ignition on or off !
    Whilst this isn't too bad now we're into summer, it's quickly going to run the battery flat. I've silenced it by pulling the blower fan fuse but obviously need a longer term fix.
    Has anyone else had this problem ?
    In addition to this cabin fan problem starting, the engine now overheats (engine oil and coolant levels both fine), but only when travelling at low speed or stationary - evidently the Engine Cooling Fans are not kicking in. Running the car parked at idle, I can hear what sounds like the relays clicking but the fans do not kick in. Could these two issues be linked ?
    Interestingly, I gave all of the engine bay relays a nudge with my thumb to make sure they were correctly seated and when I nudged the blower fan relay, the cabin blower fan switched off - now it does not work at any setting.
    Help please.....
    Cheers.
    VE SSV MY10
    Jun 2006
    Check all fuses and swap the relays out with horn or headlights as a test I might be a dud relay
  1. my thermofan runs constantly even when engine off
    By TonyJZX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2010, 08:01 PM
  2. engine runs but no power
    By MARTYMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2010, 06:08 PM
  3. Vk engine runs, then dies in reverse HELP :|
    By blinky666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2010, 09:25 PM
  4. car finally runs but runs really ruff
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2008, 02:09 PM
  5. Runs Good Runs Slugish ??????
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 04:01 PM
Tags for this Thread
