Results 1 to 6 of 6
Thread: VZ Ls1 throttle body conversion to Ls2
    VZ Maloo. 6 Speed. OTR. Tune. Some other bitz
    Jul 2010
    Question VZ Ls1 throttle body conversion to Ls2
    Hi people, just looking around on the net and saw that now you can buy a adapter plate to mount a ls2 throttle body on a ls1 manifold, now my ls1 is a vz ss with electric throttle. Can anyone here tell me if I can straight mount a ls2 throttle with the adaption plate and not have any issued with writing etc? Or what else is involved? Thankyou
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    The neck of the inlet manifold will remain the same (75mm). There is no way your gonna fit an LS2 throttle with out a different manifold! FAST etc
    But that said you can try TPIS LS6 Modified Intake Manifold For 90mm Throttle Body - Lingenfelter Performance
    Which they cut the snout off an LS6 manifold and put the LS2 snout on..
    If you get to this you will need an Torque Rush LS2, LS7, LS3 to LS1 throttle body adapter harness
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    Best mod is to fit -243 LS2 Heads & Inlet Manifold & LS2 Throttle body to LS1 engine block. You will still need the adaptor harness as the throttle bodies LS1 has different pinout plug than LS2 & also "talks" different to LS2 to ECU . The harness has a neat little metal box in it that converts all the bauds to the same language, I have done this full mod (plus 3" hurricane extractors & cats & X force 3" stainless exhaust , plus FAST LS2 injectors & high ratio roller rockers), on my 2005 CV8Z Monaro , I reckon I have 300kw easy now instead of the 260kw stock. Plus its not so "Doughy" at low revs any more. Sounds unreal too!!!!
    Monaro CV8R, Landcruiser 100 Series 4.7L
    Jun 2011
    My mate put a LS2 manifold and throttle body on an LS1 with a tune and it produced a useable improvement in low down and mid range torque. Not much more power though. I have thought of doing this at the very least.
    davleigh's Avatar
    davleigh is offline Donating Member
    Vx SS Commodore
    Feb 2012
    Sorry to hack the thread. But i can't find the answer anywhere using my phone.
    Is it possible to put an electric tb onto my ls1? And what's involved in doing so? My bro inlaw is upgrading his tb on his vz, and is going to let me have his old tb.
    Any help on what i need to do or what's involved would be muchly appreciated.
    Thanks all
    Sent from my GT-I9100 using Tapatalk 2
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    meh don't bother
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
  1. Throttle body conversion?
    By Kieran263 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2010, 02:28 AM
  2. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  3. Throttle Body 4 L67
    By VS CALAIS in forum V6 Development And Modification
    Last Post: 30-06-2006, 10:13 PM
  4. throttle body conversion
    By megee83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-05-2006, 11:21 PM
  5. throttle body
    By pizzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2005, 03:20 PM
