Results 1 to 13 of 13
Thread: DIY stock headunit mod???
    VX Lumina
    Nov 2010
    melbs
    Default DIY stock headunit mod???
    Just wondering if it is possible to install a sub into a vz sv6 without changing the original headunit. i.e can you create your own RCA input ?.
    tried to do some research on it but nothing came up
    Nothing yet
    Oct 2011
    VE SSV MY10
    Jun 2006
    as above check out the ASR thread in our sponsor section for the rca mod and if u have a ipod this guy does a cool little interface i have both in my wifes adventra as she wanted to keep the stock head unit and have a full function ipod control and sub
    ASR Audio & Electronics
    Holden VY/VZ project development chronology - udcaus
    azazeldeath's Avatar
    azazeldeath is offline Donating Member
    VZ Holden Crewman 06 6sp S pack
    Oct 2010
    Darwin, NT
    Theres the 3sixty2 and a few other things like that.
    My rides
    VZ Crewman S Pack 6 speed
    HJ/HQ One Tonner with a worked 253 and 3speed auto
    2005 VZ Storm S Ute
    Apr 2011
    Orange
    if you are only installing a sub you could run a LOC (Line Out Converter or Low Level Converter)
    it taps on to your speaker wires then has rca outputs on it
    a LOC would put out enough quality sound for just a sub and is the cheapest alternative, should be able to pick up one from your local autobarn or car store for around 15 bucks
    2005 VZ Storm S Ute
    Apr 2011
    Orange
    Quote Originally Posted by illlusion View Post
    hey mate is the ipod interface a good mod?
    im kinda stuck im not sure wether to buy an aftermarket H/U to put in my ute or continue using the original, if i do stick with the original ill definatly want the ipod interface however whats the sound quality like? i prefer the original factory look aswell
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Check the vy section, there's a sticky that shows how to connect an iPod to the standard hu. I've done it myself and it worked a charm
    Spoken by a true member of The Committee
    May 2009
    Gold Coast
    Also with the RCA, you can splice into the rear doors speakers and install a high/low converter, which lets you connect RCA using speaker wires
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    sounds like a yucky load of wiring and stuff, $200 gets you a really good head unit..
    Life starts at 200km/h
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by impulsive View Post
    Precisely. I spent a good $300+ on the stock unit installing RCAs and AUX ins and in the end it was probably a waste of time except for keeping the stock look. Line out converters are absolute shit in the quality department - even my sub sounded better when I moved from LOC's to the RCA mod.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Essassin's Avatar
    Essassin is offline Bends spacetime
    VY S Sedan, E36 318is Coupe
    Oct 2010
    Limbo
    ^ What those two said. Unless you are absolutely dead set on retaining the factory unit, just buy a new one, the standard Blaupunkt units are shithouse. Single din with everything you need + pocket for $200 easy.
    VE SSV MY10
    Jun 2006
    Yeah the iPod interface is good charges iPhone as well the wife loves it sounds good with the low level rca mod with a good amps and splits I have full after market in my clubby but
    VX Lumina
    Nov 2010
    melbs
    Yeah I really wanted to keep the original H/U so i'll give this ASR thread a try. thanks for your help guys
  1. So, you want to keep your stock headunit....
    By Tasmaniak in forum Car Audio
    Last Post: 20-06-2011, 11:03 PM
  2. Possible to run a sub from a stock headunit
    By Justanotherholdendriver in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-06-2011, 12:11 PM
  3. [SA] Stock VT headunit, Sub+Amp
    By panda88 in forum Parts And Other Items For Sale
    Last Post: 20-05-2009, 08:39 PM
  4. vy stock headunit
    By lok in forum General
    Last Post: 28-12-2008, 06:40 PM
  5. sub and amp on stock headunit
    By =Calais v8= in forum Car Audio
    Last Post: 07-10-2007, 12:37 AM
