Results 1 to 12 of 12
Thread: VZ R8 Clubsport Running problem HELP
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    Exclamation VZ R8 Clubsport Running problem HELP
    OK when the car is full it drives fine but when it gets to about 1/4 (35L - 40L used) tank it starts cutting out under load like when i take off from the lights its like is misfiring but i changed the leads plugs and coil packs and it only does in at 1/4 tank i though it might be the gauge reading but i drove it like this for another 15 litters and it just got worse but didint stall so not running out of fuel so im at a loss my exhaust bloke said my o2s looked fine and if it where that it would do it all the time so i put it down to fuel system problem all help would be good
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    02's can look fine but still be rooted. I would take it to a tuner and he'll tell you whats going on
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    it sounds like a surging issue in the fuel tank.. fuel pump or filter dirty?
    Life starts at 200km/h
    VZ Executive MY06
    Oct 2011
    Hamilton, Vic
    I'd go with impulsive, i'd be leaning towards a surging issue from the tank. Best pay to pop the pump out and have a peep. I had an 02 Xr8 that was doin the same thing, turns out i had water in the tank and when i booted it, bloody watwer would run to the fuel pick up, lol. Very embarrassing
    VC SL/E A3300 ,Looking for a VL
    Mar 2011
    armadale Perth, Australia
    Quote Originally Posted by Low06VZ View Post
    I had an 02 Xr8 that was doin the same thing, turns out i had water in the tank and when i booted it, bloody water would run to the fuel pick up, lol. Very embarrassing
    the fact you had water in the tank or the fact you owned a ford :P lol na sounds Interesting
    Black_Stig
    If Cars could scream Rape, I'm sure yours just did because I just eye fuc&ed the shit out of the above images.
    MY 1980 VC SL/E Exhaust Note
    VZ Executive MY06
    Oct 2011
    Hamilton, Vic
    Lol, the fact i couldn't overtake a bloody old campervan doin 75km/h. very sad day, funnily enough the VZ don't have this issue
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    some thing new happen today i was driving on the freeway in slow traffic and got a "check powertrain" error then it started banging though the gears all i did was drive it home so will have to go for another drive tomorrow and c if it still does it what causes this im at a loss im ready to take it to holden and say fix it all
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    check power train needs to be scanned &read, perhaps its an 02 sensor?
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    Turned out the heat shields on the spark plug leads where causing the problem cause my mechanic changed the injectors fuel fitter and even checked the pump all good even did a fuel flow check and it all working so he tried the leads and yep it was the heat shields and as for the check power train my trans is on it way out needs a rebuild
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    wouldn't the trans be part of the drive train??
    Chev badges are an instant fail
    05 VZ R8 Clubsport
    Oct 2009
    Melbourne VIC
    Quote Originally Posted by ashbox View Post
    yeah the trans needs a rebuild
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    my point was, thats drive train not power train
  1. vl V8 running problem
    By LUMPY 8 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-07-2011, 11:34 PM
  2. VS Clubsport Running Rich
    By Lady Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2011, 02:05 AM
  3. vp running problem need help
    By joshooaahh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2010, 07:24 PM
  4. VR running problem
    By Doddsy18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 03:06 PM
  5. Vn problem running crappy
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2005, 06:36 PM
