Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By RiCeY
Thread: VZ ute fule tank problem
    Vt Acclaim
    Apr 2011
    kepnock
    Default VZ ute fule tank problem
    not long bought a vz one tonner ute from a car yard and have had trouble with the fule tank. It dosent let us put in any more the 46 liters in the tank. the needle on the guge is showing full and when it nearly empty its on empty. we have sent it back three times to the car yard and they replaced the fule pump inside the tank but still cant fule it any more then 46 liters. Anyone got ideas on what it could be.
    Such is life
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If it only takes 46 litres then its not empty. Theres a common issue with the arm on the sender being bent in a way that the guage reads empty when its actually on about a quarter.
    The float arm should have a 90 degree bend in it at the lower elbow (not where it comes out of the pump assembly). Simply bend it to 90 degrees and it should read correctly.
    Silver Certified.
    SVZ Ute
    Dec 2011
    Baldivis, WA
    Youre float is probably dodgy like mine... says empty (as in 0 kms to go) when theres an extra 20litres in the tank. Holden tried to say its meant to be like that but my mechanic (been used by the family/dad for nearly 20 yrs) said it was the float and could be fixed but no issue really I just know that I have more than it says although as soon as it gets to the start of the red line - 90KMS to empty I fill it cos I dont like to run any car down.
    Vt Acclaim
    Apr 2011
    kepnock
    Quote Originally Posted by RiCeY View Post
    Ok thanks a lot for your input RIcey.
    Such is life
    Vt Acclaim
    Apr 2011
    kepnock
    thanks for your help we took it to the car yard we bought it off and they said it was a blockage in the line stoping the fuel from getting to the other half of the tank. where not sure yet if it fuels up as they put fuel in it.
    Such is life
    WL Caprice
    Mar 2011
    Same issue - on empty can only squeeze 55 into a 75 tank. By my thinking, I can make passengers panic by doing a run from Brisbane to the Gold Coast.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by tayna17turbo View Post
    More likely they forgot to plug the line in after replacing the fuel pump.
    Silver Certified.
  1. VY v8 fule economy
    By neppirt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-09-2009, 02:46 AM
  2. [NSW] WTB - Metalic silver vx fule door.
    By kizza_VL in forum Swap / Wanted to Buy / Trade
    Last Post: 27-07-2009, 06:15 PM
  3. Standard VN Fule Injectors
    By Satanic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2008, 08:43 AM
  4. internal fule pump
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 08:23 PM
  5. what fule do ppl run their cars on, Petrol or LPG?
    By jd hot stuff in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2006, 02:19 PM
