Results 1 to 16 of 16
Thread: SV6 wheel squeak?
    Vn
    Feb 2010
    Default SV6 wheel squeak?
    Wheel started squeaking a little while back, maybe 2 months ago, i got car serviced, new brake pads, etc.
    Wheel is still squeaking, no idea what it is, maybe the bearings? Brake pads are about 2-3 weeks old. I think its only the front right.
    Squeaks nearly all the time, sometimes it stops, squeaks when im goin 10km/h or 100km/h doesn't matter.
    Heres a video i recorded, sounds exactly like that, any ideas?
    Untitled on Vimeo
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Quote Originally Posted by HoldenV8 View Post
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    Mate are you ok in the head? WD 40 on brakes? They'll slip like a mofo, pad will barely if at all bite the rotor!
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    ffestival is offline Banned
    Ford WB Festiva
    Nov 2011
    Darwin
    it works with my festiva, i spray wd40 in the rear brake drums and on the front brakes and it stops the noises for a while
    VY S/II S Pack
    Apr 2011
    Cause lubricating a part that is designed to slow the entire car through friction is a bright idea...
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    lol @ spraying lube on brakes.
    Does the noise go away when you apply the brakes?
    Silver Certified.
    WL Statesman
    Nov 2011
    Maryborough QLD
    This is probably caused by the pads chattering, there is something like hi temp silicone that
    can be applied to the back of the pads where they contact the caliper piston.
    Repco or a good brake repair workshop should be able to supply it.
    WL Statesman
    Nov 2011
    Maryborough QLD
    Also check the pads are fitted correctly, there are flat spring bits riveted to the pads, one of these may not be sitting
    in correct position and may be rubbing on the disc
    Vn
    Feb 2010
    Yeh the noise stops when I brake.
    Edit.
    Also, my mate said when i gun it, my car smells weird, he said it smelt like the stuff you out on an exhaust to get fingerprints off or something?
    Is that anything to worry about?
    VZ Executive
    Oct 2011
    Vn
    Feb 2010
    nah dont think so.
    Also, just went to a mates to get him to sus it, said its the back not the front.
    WL Statesman
    Nov 2011
    Maryborough QLD
    VZ SV6 2005
    Jan 2012
    Ive got the same problem with my VZ SV6 but i think its the front on mine because when i turn left it goes away but when i turn right it gets even louder. any speed will do it but braking stops it. im thinking brake pads which ill get done on the next service. but if its still there ide like to know what to do.
    Willo
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    your pad is rubbing. Think about what side it squeaks and what turn makes it worse, then think about what cornering will do to your wheel. That should tell you what pad is rubbing.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    VZ SV6 2005
    Jan 2012
    Its the right one, and its when i turn right it gets worse but left will stop it.
  15. #15
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  16. #16
    VZ Calais 3.6L
    Dec 2011
    Sydney, Australia
    Just an FYI the whole WD40 thing... I've heard of this done before, and it doesn't have to be WD40, it can be any oil really. It's supposed to be applied to the REAR of the pad, not the pad surface. This will allow the rear of the pad to move slightly on the piston and not rub without lubricant. This stops squealing from this location. You need to remember that squealing isn't only caused by the pad vibrating/contacting with the rotor.
    The other option to stop this and probably the more effective/long lasting is what 55ZED mentioned, you can get stuff called CRC Disk Brake Quiet which you apply to the rear of the pad and it acts like a glue which holds the pad to the piston so it doesn't flop around.
  1. squeak
    By jimmythesaint in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2011, 09:03 PM
  2. Squeak coming from rear wheel?
    By Mase1990 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-04-2010, 07:37 PM
  3. VT right hand rear wheel squeak
    By Warface in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2010, 05:20 PM
  4. VS wheel squeak
    By Shtato in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2009, 08:43 AM
  5. VX Squeak?
    By Ray De Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2009, 02:14 PM
