Results 1 to 11 of 11
Thread: Strange stain under my car
    VZ Executive
    Dec 2008
    Default Strange stain under my car
    Hi Guys, I moved my car this morning and found this stain underneath (Image Attached) Is it coolant? If so what could be leaking since it's under the back of the engine.Strange stain under my car-img_20111221_123147.jpg
    Thanks Guys.
    Couldn't be without my Commodore
    VZ Executive
    Oct 2011
    VZ Executive
    Dec 2008
    No, and it's been sitting there for about 2 days.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Actually looks like the mark left after a battery has been washed down. Could be coolant though.
    Visit my Facebook page
    VZ Wagon
    Jun 2011
    Brisbane North
    Certainly looks like coolant because it has stained the concrete and just because it is at the back of the engine does not mean much, I had a VP water pump leak and run along the sump then drip off the rear.
    Are you losing coolant, have a good look around your engine and see what you can see.
    VZ SS
    Jan 2012
    Default Coolant leak
    It is a coolant leak, i would check out the hoses that ran from your heater tap to where they attach to the firewall it may be split, hence the fluid at the back of the engine.. I had this same problem
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If the heater hose quick connectors leak it can run down the exhaust and the back of the engine.
    Silver Certified.
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    hmm A/C fluid ?
    if it is the concreet is quite white in center then goes to that brown coullor then back to normal?
    hj kingswood
    Sep 2011
    Melton
    Has it got steel welsh plugs? Often rust and leak, prob not, but often overlooked, though not sure of your engine.
    VZ Calais 3.6L
    Dec 2011
    Sydney, Australia
    It's coolant. You can tell by the watery look but with the slightly dirty mark, prob a little oil or some contaminants. If you want to be sure stick your head down there, if it smells kinda sweet then it's coolant. It's not oil, and if it were water/condensation from the air con it would have dried straight up. It's coolant.
  1. Stain remover
    By Haluigi in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-11-2010, 04:16 AM
  2. remove stain?
    By Tony_harrison in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-07-2010, 03:49 AM
  3. stain removal
    By fish32 in forum Car Care Products
    Last Post: 17-05-2010, 08:43 AM
  4. Can you stain?
    By Trayner in forum General
    Last Post: 08-11-2008, 03:43 PM
  5. Ambi Pur Stain
    By Super Snake in forum General
    Last Post: 25-01-2006, 05:15 PM
