Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: brakes
    05 vz acclaim
    Jul 2011
    Default brakes
    got $450 for chrissy and need to do my breaks. 450 is my budget and i need new front and rear disks and pads. happy to throw a few extra dollars at it if it will be worth it.
    any suggestions or advice would be great.
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    are you competent to do the job yourself or will you pay some one to do it?
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    05 vz acclaim
    Jul 2011
    nah im capable of doing it myself have done the brakes on a VR, pretty sure its the exact same in a VZ so the 450 is straight to the pads and rotors
    05 vz acclaim
    Jul 2011
    rear-http://www.ebay.com.au/itm/170653555492?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_2663wt_730
    front-http://www.ebay.com.au/itm/170653554909?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_2663wt_730
    thats what i was looking for as far as disks, just a bit lost on brake pads. looking to spend roughly 60-70 bucks an axle on pads.
    vx
    Aug 2011
    sa
    use bendix pads about $140 front/rear, here in sa we can get two front discs for a $100 bucks, rears the same price, so about 350 bucks with a can off brake cleaner ,,,
    Jan 2008
    NSW
    Dont blow the whole lot if you dont need to. Do you really need new discs? If not just get them machined, usually around $25each and a set of good bendix pads should be around the $140 mark. The whole thing should set you back $240 give or take a little.
    Unless you need new discs, then thats a different story. Perhaps drive to a trusted mechanic and ask his professional opinion, discs or machine.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Use Bendix GCT's. For what they cost they are unreal. $70 front pads and same price for rear pads. Pulls my VY up heaps better than whatever Holden put in on the production line. As for rotors, maybe DBA slotted? Around $100 each, so you'd be over your budget, but you can't expect decent stuff for less than around $520 all round and that's if you do your own labour.
    vz sedan vs ute
    Jul 2008
    newcastle nsw
    i had to by a tourqe wrench and hose clamp when i done my vz brake rotors ,clamp the hose and undo bleed nipple when pushing piston in , so u will not push brake fluid back up to your ABS unit (dont forget to top up reservoir) and u must tourqe the wheel nuts...vs ute has no ABS so less ####ing around when changing pads or rotors
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Speak to GSL Rally sport, he does some good brakes for cheap prices, dont go skimp on brakes, QFM HPX Brakes are a good upgrade, well worth the extra imo.
    as above, wond need to clamp the hose, but get a clamp to compress the piston... before you drive, pump the brakes 10 or so times to rebuild the pressure etc
    Edit again: No torque wrench, as tight as possible is good, if you are a tiny weedy little man (lol) thread lock that shit...
    Life starts at 200km/h
    05 vz acclaim
    Jul 2011
    im not to keen on blowing it all either, but i am definitely due for you discs and pads.
    yes i understand im not going to get great stuff for 450 mark but its my everyday car the gets a burn through the mountains every so often.
    found what looks to be an alright little package on ebay - eBay Australia: Buy new & used fashion, electronics & home d
    figured it would be worth grabbing an opinion on.
    cheers for the great advice so far
    vx
    Aug 2011
    sa
    vr commo
    Aug 2011
    places
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by stick3 View Post
    Never ever done this. No need for it. Never seen a single ABS module shit itself from fluid being pushed up through it.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vz sedan vs ute
    Jul 2008
    newcastle nsw
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    standard rear brakes, peformance front brakes, dont sacrifice safety for money.. If your gonna go cheap, at least go standard, as you know they work... $450 is a lot of money too
  16. #16
    vz calais 2005
    Dec 2011
    If you live in Melbourne tehre is a place called Better Brakes in Moorabin who always does a good deal on brake components.
    Also super stop brakes in Box Hill i think is quite good and reasonably priced.
  17. #17
    05 vz acclaim
    Jul 2011
    so am I best off just sticking with genuine parts than trying to do aftermarket on a budget?
  18. #18
    VX acclaim S2
    Oct 2009
    Quote Originally Posted by vzaccaz View Post
    Not at all..... front and rear pads, $25 a set, and DBA disk brake Australia, $250 for the lot... Cj auto parts in cranbourne. Slotted disks too
  19. #19
    05 vz acclaim
    Jul 2011
    easy done, well CJ auto parts has got me so far, might check super stop brakes in boxhill as it is much closer.
    but DBA's all round and some pads and some brake fluid for a full system flush sounds like the plan.
    cheers for all the help
  20. #20
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Pushing fluid back through the ABS unit didn't hurt mine. Same with flushing/bleeding, just like doing a non ABS vehicle.
    Non genuine does not necessarily mean that the quality is poorer. On the contrary, Bendix GCT's are so much better than my old factory pads were.
  21. #21
    VZ Calais 3.6L
    Dec 2011
    Sydney, Australia
    I upgraded to slotted twice, once with RDA's which were horrible, and then with DBA's which have so far been awesome. I went for ferodo pads which again have been awesome. When I was talking to the guy about it (This guy ONLY sells and fits brakes, he has a warehouse full of them so I assume he knows his stuff) he said the Bendix rep told him that Bendix do not make pads for slotted rotors, they're simply not designed for it. Now I assumed that there wasn't much of a difference so I didn't really care in the past, but the fact that the Bendix rep told this guy that makes me think maybe there's a reason for it... my guess is the rep doesn't want this guy having p***ed off customers saying the product was horrible and not buying it so he told him so he wouldn't sell it that way... just an FYI. Your choice, I'm just letting you know what he told me.
  22. #22
    06 VZ Executive
    May 2008
    Sunny Coast Qld
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by ozzypole View Post
    Check this out before you commit to anything.
    QFM HPX VT-VZ Police Spec Performance Brake Pads
    I have these on the car at the moment, i suggested these earlier i think too. Definately a good pad, from my experience...
  24. #24
    05 vz acclaim
    Jul 2011
    i have heard alot of good things about the QFM pads, but are the not about 120 a set? i cant justify spending that money on a car that doesnt get driven hard enough that frequently
  25. #25
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Go to the top of the forum and look in GSL Rallysport. Post in there with all your questions and Greg will give you some honest and professional advice to keep within your budget.
  1. Difference between VT HSV 296mm brakes and normal VT 296mm brakes
    By CHEETR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2011, 11:23 AM
  2. ve brakes and cross8 brakes
    By slow vs in forum GSL RallySport
    Last Post: 26-09-2011, 10:53 PM
  3. C4 Corvette Brakes VS GTS Brakes
    By gibbonsVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2011, 08:58 AM
  4. [VIC] vt sloted brakes-vy calipers, vr frnt/back stock brakes & calipers, vy braker booster
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 23-03-2011, 02:12 PM
  5. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
