Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Lost all gears (Suddenly) engine running
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Exclamation Lost all gears (Suddenly) engine running
    Yesterday when leaving work, I drove out of the space in "D" then 4 seconds later I had no gears! It was like I put it into neutral while driving. I pushed it to the corner and stopped, shifted up and down through gears and nothing. If i revved it in (D) there was nothing, even reverse didnt work. I turned engine off and called a friend. 30 mins later I tried the same thing, slot into (D) and nothing so I checked under car and couldn't see anything loose or broken.
    So friend arrives and trys same thing and nothing to be seen wrong, so i get back in, put it back into (D) and revved it to about 5 rpm and car started moving as normal.... FTW!!! Nursed it back home, upto 60, changed gear fine and seemed normal....
    What's going on with my car, it has never done this before. Is it something major or is it a simple fix? Nothing too expensive i hope!
    BTW its a 5 speed auto, SV6.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    How do you do that mate? Thought you couldn't check the fluid level as there is no dip stick?
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    give it a service, but thats not a good sign
    Going where no late model stato/caprice has gone before.... GAME ON!!
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    walesy's Avatar
    Jun 2005
    Perth SOR
    yes most gearbox dipsticks are close to the firewall on the drivers side, check your trans fluid while the car is running at operating tempreture
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If theres no dipstick you have to get the transmission fluid temp between 30 and 50 degrees then remove the fill plug off the side of the tranny, engine still running, and top up till its flows back out.
    Dont turn the engine off at any time with the fill plug removed.
    Silver Certified.
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    So its something simple like an oil change? Is it something I can do or better to get an trans machanic to do it? How do you top up the fluid at the same time as draining?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    And youll be lucky if thats all it is, best bet is get an auto trans specialist to have a look.
    Silver Certified.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Torque converter or Transmission fluid pump... It won't be fluid level that makes you "suddenly" lose gears.
    Fluid level will make you slip.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    If its the torque convertor what am I looking at forking out for one? And if its the pump wouldn't they replace the fluid at the same time? I'm guessing both them parts aint something easy doing so does anyone know where I can take it?
    Cheers for the responses....
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    If there is no hydraulic fluid, which is essentially what auto trans fluid is. there will be no hydraulic pressure, thus the car will not change gears.. just like a crane, not hyrdraulic fluid, no lift...
    Life starts at 200km/h
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by Ray De Man View Post
    Both jobs is a box out job to fix.
    It's not likely to be a loss of fluid situation, like Hoz explained. I'd save yourself the time and effort by taking it to a trans joint.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  15. #15
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Quote Originally Posted by HoZy View Post
    Mat
    This!! I had this happen not to long ago, there may be a chance some damage has been done to the gearbox if you have driven the car for too long with damage to the tranny pump. Get it looked at ASAP!!!
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
  16. #16
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by Sabbath' View Post
    How can you be sure? I'd rather save a lot of Money then 5 Minutes by checking an oil level and being sure!
    However, if the fluid is fine, get it in to a shop
  17. #17
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by impulsive View Post
    Sure, 5 minute job to sus out if the oil is fine is a good starting point. Although if you read back what i said, i agreed with Hoz about the loss of fluid not causing an instant onset of loss of gears.
  18. #18
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Your right there, if its instant then there would be some form of fluid loss, hopefully he didnt miss a big fluid spill.. In this case i too doubt it would be lack of fluid
  19. #19
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    There was nothing leaking under the car when it happened and checked again when i drove it back home.
    Everything sounds expensive, guess i could be expecting a $1000+ bill.....
    If lack of fluid or problem with pump, why car still drive afterwards like nothing was wrong? Is this a common problem with auto's?
  20. #20
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    forgot about the bit you driving it home, wont be fluid loss then.. From the couple of times ive explored the numerous websites i can't recall much about this kind of thing, so from my point of view, not very common.
    Hasnt done it since? Could be the start of a problem or the car was having a bad day?! I wouldnt concern myself unless the gearbox started playing up or did it again
  21. #21
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    As said if the fluid was low enough to result in loss of drive the problem would be constant, not intermittent.
    Silver Certified.
  22. #22
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Not started car or even moved it since I parked it. I don't know what to do, wether chance driving it to see if it did it again or leave it until I can afford to get it inspected and repaired? I need my car for work and being this time of the year it's hard to book in anywhere....
  23. #23
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  24. #24
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    ok cheers mate, will try run car around block just incase.... Hopefully it'll be ok just to get me by untill i have funds to get the gearbox checked and serviced and most importantly get me to work otherwise no funds! Will keep you guys posted if I hear any strange noises or anything....
  25. #25
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Please do, i would like to know the cause of the problem.. hopefully its just a one off though
  1. VT V6 auto gearbox trouble, lost gears
    By kiwi pup in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2010, 09:58 PM
  2. HELP lost all my forward gears any ideas?
    By VYBR8R in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-06-2009, 02:11 PM
  3. driving along when suddenly all power is lost
    By arc angel vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 08:40 PM
  4. VN Commodore S suddenly running ruff
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2009, 12:47 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
