Results 1 to 6 of 6
Thread: which oil in vz lsd?
    vz Executive
    Aug 2011
    BF BEND
    Default which oil in vz lsd?
    hi all, i'm going to change the oil in the lsd on my vz exec,v6 auto, 57k. I'm hoping that this will take some of the backlash the lsd is exihibiting, what i want to know is there an oil that that is a known and proven help with backlash, not after a favourite brand but something that helps, thanks for any help, Iva.
    what we have here,is a failure too communicate!!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    I use penrite limslip 140 with limslip additive but have upgraded the gears/shims etc
    if you want the best go for mainlube 154 75/140 no additive needed with that one
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    No oil will get rid of backlash unfortunately.
    Only a rebuild will cure it.
    Silver Certified.
    vz Executive
    Aug 2011
    BF BEND
    Quote Originally Posted by RiCeY View Post
    YES RiCeY, well aware of need too rebuild, the diff was really slack few weeks back and was making d-r selection difficult, so clunky i thought the trans had shit, did'nt drive for a week then decided to have a look underneath, this aint easy for me, 198cm-116klg,car Fe2, anyways got assistant to select DR , front of diff turning and clunking, ok so i decide to drive car and it's returned to normal, that is with just minor clunk on gear selection, i know this is'nt normal but i can live with it . as this problem seems to be intermittent i hoped that an oil change with the best may buy me some time before the rebuild.
    VY SS
    May 2011
    Auckland
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    If the teeth have lost their hardening, they will wear rapidly. I'd have the money in my pocket if I were you.
    Even changing the oil to examine what metal has come off the teeth would be helpful, use a magnet.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
