Now, I'm hooking my aftermarket aerial up to the rear window heat filament to get better reception, however, I can't find the small black box which the wire joins the rear window anywhere! Any ideas where it's located?
I tried this in my VL and it kinda worked but gonna go for an aeropro internal aerial instead
and what happens when the demister is switched on? or are you disabling it? I'd hate for it to heat up the wire's and burn something
The aerial has it's own control box (it's after market) and for greater reception, I need to solder a single wire to the control box. So it will just use the fillament to transmit the frequenciesShouldn't burn etc... when the demister is turned on.
I just can't find the "control box" anywhere!![]()
That's coz the bcm controls the rear demister
There is no control box the wires simply plug into tabs on the rear windscreen.
Silver Certified.
I dont see why not. You need to remove the C pillar trims from memory can remember if they are on one side or both...
Silver Certified.
Ah ok, so basically just remove the side seats, and then the C pillars? Don't need to remove the parcel shelf etc..?
Yeah not sure never had to remove them before...
Silver Certified.
Why don't you just use the mobile phone ariel box at the top of the rear screen?
There is a mobile phone box in ALL VZ's? I have a VZ executive...?
I thought they all had them. Could be wrong though. Not 100%.
No they dont, aftermarket.
Silver Certified.
