Results 1 to 12 of 12
Thread: Knocking, front end
    VZ Wagon '06
    Nov 2011
    adelaide
    Default Knocking, front end
    Ive recently been hearing a knock/cracking sound. As if the front end is "cracking a knuckle" so to speak
    Seems to only occur when its being pressured into it for eg. if i turn right into a round a bout and as i exit and change direction to the left, there it is..... Im not sure if i can feel it in the steering wheel or if its passing the vibe to it.
    A possibility might be the rhs strut rod. Looking at the left hand one, the rhs seems to have around 10 mm less thread on it. Might need tightening up to make it the same as the left. Before doing this tho, im unsure if i will upset the balance of things if i tighten it up...
    VZ Wagon '06, Odyssey
    vz Executive
    Aug 2011
    BF BEND
    both struts should be tightened and have no movement in them .
    what we have here,is a failure too communicate!!
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Also check your sway bar linkages. Mine were loose and caused a similar knock. Be sure to check them soon because the more linkages knock and move the more they wear, if you leave it too long no matter how tight it is it will still knock, then you need a new sway bar.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    VZ Wagon '06
    Nov 2011
    adelaide
    After some inspection i have concluded that the sway bar is not centered. Its seems that for 1, the mounts on the chasis arent the same on each side. Looking at the lhs brace theres 15 mm before it bends down to meet the links,,, on the rhs it bends down imediately after the brace. And 2, the strut rod is touching the sway bar on one side where as on the other side there's enough room for 2 fingers... any size.
    Not knowing anything about wheel alignment, i suspect i should loosen the sway bar unloaded??
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    You mean like this?
    Passenger side
    Drivers side
    You can see the part of the bar on the left that is cleaner where it was under the bush.
    vz Executive
    Aug 2011
    BF BEND
    replace the bushes, the top ones will be stuffed too.
    vs ute
    Oct 2011
    vr commodore v8
    Oct 2005
    Melboune
    make sure u haven't run ova something or bottomed out and bent the sway bar somewhere ... otherwise probs just the bushes or links may also be bent
    VZ Wagon '06
    Nov 2011
    adelaide
    Quote Originally Posted by shanen View Post
    You mean like this?
    Passenger side
    Click image for larger version.
    Drivers side
    yes, just like that.... Can you show us the strut rod bolts. Im interested to know if you have equal thread on each side. (you can just post a reply no need for photo)
    cheers
    Quote Originally Posted by revhead1988 View Post
    The links are strait, but i dont know about the sway bar yet. Probly need to take it off and view it from a few angles to check it.
    VZ S 175 Ute
    Nov 2010
    While we are on the subject of sway bars, has anyone replaced or fitted one yet? I've just bought a new sway bar because the last one was damaged.
    After looking over the job I can't help thinking I'm going to be stuck removing heaps of crap trying to get it in, I wanna know if its an hour or 3 hour job. Its the front bar.
    VZ Exec Wagon MY06
    Aug 2008
    Cairns
    Quote Originally Posted by kubsnazx View Post
    cheers
    I have equal thread on both sides.
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Im getting the same problem, the left strut just turns freely, but the right is solid as... how do you tighten them ? hold the top part and tighten the bottom or just get a socket on it and tighten, if its the latter nothing happens just keeps turning
  1. Knocking Sound From Front end
    By eko in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-05-2011, 05:46 AM
  2. VY Storm Front-end knocking noise
    By gordo881005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-12-2010, 07:25 AM
  3. Knocking the the front end MY10
    By jmancool in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-11-2010, 01:46 AM
  4. Knocking from front suspension
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 08:40 PM
  5. Front knocking ....
    By Vc_Sleeper in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-02-2007, 06:57 AM
