Results 1 to 3 of 3
Thread: shaking when ac is on
    vx acclaim
    Sep 2011
    sydney
    Default shaking when ac is on
    question,,,the wifes vz when at traffic lights shakes and shutters with the a/c on when ya turn the a/c off its ok ,,,,,
    could it be the injectors,,,really confused,,,did have a sluggish problem before but thats been fixed wiyh new spark plugs,,,,
    it starts coughing and shaking in drive or reverse mainly in park not so bad,,,but only when a/c is on,,,,any ideas,,cheers
    vx
    Aug 2011
    sa
    iac valve, or some people call it a idle up control valve, basically it increases the car idle when the air con is on.
    VZ 06 Exec
    Dec 2007
    Sydney, NSW
    The vz has an electronic throttle so it just opens up 1-2% more when the AC is on. It has no IAC valve.
    You should clean the throttle body... See if that helps. They build up a bit of gunk just after the butterfly.
  1. my car is shaking - vx berlina
    By zenna in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2010, 08:51 AM
  2. Shaking Vt
    By adamrollo9 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2010, 06:32 PM
  3. Shaking car :(
    By VSPantha in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2010, 09:36 PM
  4. really bad shaking
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 10:38 PM
  5. Steering Shaking
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 01:07 PM
