Results 1 to 5 of 5
Thread: Climate problem!
    VZ Berlina V6
    Jan 2012
    Cranbourne
    Default Climate problem!
    Firstly hi to all members as im new here.
    OK, i replaced the battery in my VZ Berlina V6 due to it being flatter than a pancake! all seems well except for the outside temp is stuck reading -40 degrees.... WTF
    So my question is how do i fix it? Will it cause the climate to always heat the cabin because it thinks its freezing??
    Thanks in advance, Ch3wy.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Try resetting the car again, remove the battery neg terminal for about 3 minutes. Remove the fuse for the climate control even, dunno if this will help tohugh
    Life starts at 200km/h
    VZ Berlina V6
    Jan 2012
    Cranbourne
    WOW :O That actually worked...... Thanks so much impulsive
    Quote Originally Posted by impulsive View Post
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    sometimes i find that my car has a spaz, i do these steps and it usually sorts it self out, only problem is retuning the stereo. ive written my settings down now
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by Ch3wy View Post
    Outside temperature has nothing to do with what temperature the climate control blows out.
  1. Climate control problem
    By dmbillo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2011, 05:26 PM
  2. VS climate control problem
    By Asmodai78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2011, 06:18 PM
  3. Climate Cluster Problem
    By edals in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2009, 10:45 PM
  4. VS Climate Control Problem
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 05:36 PM
  5. Climate Control Problem
    Last Post: 03-08-2005, 09:37 PM
