Since having the ignition barrel replaced (was jamming) some six months ago an intermitent starting problem has developed. When I turn the ignition key nothing happens as if the battery was dead flat. I take key out lock/unlock, close/open doors etc but still won't start. On the three occasions this has happened, and whilst waiting for the NRMA the engine has started on a subsequent attempt after about 10 minutes.
My initial thoughts are that there may be a loose connection as a result of the ignition barrel replacement - however the starting after a 10min delay is puzzling. On the three occassions this has happened then engine has been hot.
i had similar problems recently and it was the key reader which activates the immobiliser when it should be deactivating.Replace the key reader and check that wiring is still plugged in to it.
what we have here,is a failure too communicate!!
Thanks for the reply.
I was going to start with checking the electrical connections. Where is the "Key Reader" located and what does it look like?
Have similar issues myself, however with mine, it comes up with very low fuel, service vehicle soon, contact dealer, fuel gauge error. Leave it for a bit then it starts. Any thoughts? Will not start after disconnecting battery, nor with the spare keys.
the key reader is located on the end of ignition barrel where you insert the key, it is the metal ring contained in a plastic case that puses on to the end of the barrel, when you insert key into ignition the metal ball on the key depresses the reader in, there are 2 wires at the back of the reader, your new ignition needs to be coded to your old keys, try pressing unlock twice, it worked for me untill i fixed it, good luck.
Same thing happens on my car.
When hot will not start until it cools down..
I have posted in another thread some of my other symptoms, but they include
- Fuel Gauge Error
- SVS warning
- Fuel Gauge showing no fuel when full
- Relays are becoming very hot when car is running, and while this will not start mystery is happening
Im looking for a short circuit or bad earth at the moment, a few people suggested it could be an ecu with issues, but I dont understand how that would cause multiple relays to become hot.
Check your start, ignition, fan, ecu, blower relays (some under dash, some in engine bay), are they to hot to touch?
i had the same problem with myne karwaliski.. turned out to be a faulty ecu... but i had the same symptons as you
