G'day all im just wondering if it is possible to put an aftermarket head unit in a vz and still be able to use the steering wheel controls, if so does anyone have a wiring diagram to do this.
any help greatly appreciated.
Here is the dash fascia you'll need for a VZ for a single DIN head unit.
Here is the steering wheel control harness you will need, when you buy it, you need to ask for the last cable piece suitable for your head unit, eg. Pioneer, Sony, etc
You will also need to get a VZ harness that you wire upto the harness that comes with your unit.
For finding out what you need to wire where, the factory head unit gives you the PIN out info on a label on the top of unit.
You then match this up with the new head unit and then wire the harnesses together.
All of this is available from places such as JB HiFi or Autobarn.
just one hint for you if you buy a premade harness, the iso pinout on on the commodores are really not iso, for some reason holden swapped ign power and battery power leads around, if you expierence memory loss on your new deck you will nedd to swap these two wires around.
