Results 1 to 11 of 11
Thread: VZ Alloytec will not start.
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default VZ Alloytec will not start.
    This isnt like anything else i have experienced. Sometimes it will start, just by luck.
    Key goes in, Engine gives that little whine and goes through check. Hear the fuel pump whine. Turn key to start engine. Nothing. I could do this about 25 times and on the 26th it might start, or i could do it 3 times and it will start on the 4th. all random.
    Have had the battery checked and passed test at 580 on 75%. Battery out and recharged overnight to be sure. Starting the car, the Voltage Reg in the dash menu (mode and set) doesnt budge off 12.5 when the ignition is turned over. Im suspecting something to do with the starter motor.
    To add to the problems, had the ignition on, removed fuel pump relay.. SVS warning. Fuel pump still working, so its not an issue. Anyone have any other options?
    Life starts at 200km/h
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    It does sound like a starter motor issue, take it to an Auto Electrician they will be able to tell you. Let us know what it ends up being.
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Cant drive it without having to roll/push start.. SVS went away after roll starting.. im guessing starter..
    jUST GOT QOUTED $465 for a new one!!! ridiculous
    vx
    Aug 2011
    sa
    VZ commodore
    Apr 2011
    perth
    same thing happened to my mums laser the other week. turns out it was the crank angle sensor....
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Still no luck, staerter has turned out ot be fine.
    Here are the steps ive taken
    1) Battery tested at 580 & Passed, 600 and Passed
    - Battery charged overnight aswell
    2) Short out Starter Relay, car did not turn over
    3) Starter Relay tested, works fine
    4) Removed Starter, had it tested, spins up fine.
    Next step is to start looking at the immobilser, cant find a fuse or relay for it anywhere.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    your key might be flat? they charge while in the ignition. leave it in the ignition for a while then try?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    wasted money if a scan tool shows nothing? Is there anything else to try before i look to the mechanics?
    vz exe.
    Nov 2010
    Vic.
    Mine occasionally does something similar. Insert key, turn it & nothing happens. My remedy was remove key, open & close the door, lock it, then unlock and try starting again. Hey presto it worked 1st go.
    Same thing if the remote won't lock the doors after getting out. Restart car then try locking doors, again it worked after doing this.
    When I did the ICC testing for the F territories they told us to do the above procedure for certain things, apparently it resets the computer or something? Anyway I tried this and it does work on my car!
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    $20 later, the auto electrician seems to think its something to do with the starter solenoid, new solenoid for $135. All i have to do is remove the starter... again
  1. Alloytec hard to start after sitting for awhile
    By lukusdesmus in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-01-2012, 08:13 PM
  2. VZ Alloytec wont start
    By charliebrown069 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-08-2011, 08:46 AM
  3. Alloytec engine clattering on start-up
    By twb1979 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-03-2010, 05:20 PM
  4. Where to start for cheap kilowatts - 175kw Alloytec
    By noddy9 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-09-2006, 03:34 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
