Results 1 to 20 of 20
Thread: engine rev capping at 4000 rpm HELP!!!
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    Default engine rev capping at 4000 rpm HELP!!!
    can someone tell me why my car is capping at 4000 rpm whilst driving.
    its done it before when i had low oil but we put some new oil in and reset it back to factory standard and it worked fine after that.but this morning i was on my way to work and my fuel empty said empty and it started capping at 4 gran again wouldnt go over.My foot was still on the accelerator but it was slowing itself down. as soon as my fuel guage went to half the car started running fine again. are these cars built with a fail safe system or something?? its a VZ SV6 alloytech. it also did it when i pulled over to check what was wrong. but after the fuel guage went up it was reving like normal
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    are you retarded? im asking a question because i dont know much about the VZ's so unless you got some useful information, piss off
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Sv6 Commodore :) View Post
    That book in the glovebox, You know. The one about your car.
    Read it...
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    I've never had a prob with mine when fuel is low. What do you mean by the fuel gauge goes back up? Randomly or you refill it?
    Spoken by a true member of The Committee
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    randomly, the gauge is a bit dicky i spoke to a mechanic he said it could be fuel pressure, hasnt got enough to give me the power for the car to go over 4000rpm
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    So you let both the oil...and the fuel get to low levels?
    Obviously you enjoy expensive repair bills.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    05' VZ Exec
    Jul 2009
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Ok, seriously, when you hit 4000, does it it feel like it progressively hits it limit, or does it go BAM!!! IM NOT GOING ANY FURTHA!!!!
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Is rev capping like mang mang mang mang mang?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VZ Wagon '06
    Nov 2011
    adelaide
    If i hold my foot flat in park it caps at 4g.. sounds like you have an issue with the car thinking its still in park. But i dont know jack......
    VZ Wagon '06, Odyssey
    VZ S 175 Ute
    Nov 2010
    Sounds like an issue that can't be answered by a forum. Best to take it to your mech.
    04 VZ SV6 A5
    Feb 2010
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    it hits 4 grand and basicaly goes IM NOT GOING ANY FURTHER it does it in nuetral as i have a manual and whilest im driving in all 6 gears. it hits 4 grand and sits there reving wont go any further at all but after 5-10 kms of driving the problem disapears and the car will return to normal and rev right to its limit
  15. #15
    04 VZ SV6 A5
    Feb 2010
    lulz safety feature ?
    safety feature? maybe its not a good idea for you to have the ability to rev to 15thousand rpm without the oil heating up a bit???
    Read it...
    should be your first point of reference...
  16. #16
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Why u revving to 4k in neutral?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
  17. #17
    VL berlina 3.8 v6 supercharged. VZ Calais V6.
    Jul 2011
    Australia, Brisbane
    I'd say it was to test his problemto see maybe id it occurred in neutral too!!!:O :O Wow some real wankers on here! Use ya ####en brains!
  18. #18
    SV6 3.6L Alloytech
    Dec 2011
    Collie
    Quote Originally Posted by Chris1991 View Post
    see this guy seems to have an idea of why i would rev it to 4g in neutral. look the problem comes and goes seems to be doing more and more as the days past. mostly does it when the car has been sitting in the sun for a few hours so its got me stuffed as to what the problem is
  19. #19
    Null
    Jan 2012
    mean some of you guys are harsh, the guys just asking a question. Ive heard of these models burning oil. have you been regularly checking stipple things like sump levels? I wil be the first to admit I don't know much about car motors but I also use to go over everything I DID know about my car at least every couple of weeks.
  20. #20
    Mar 2008
    What you should do is try and engage cruise control when its having a 4K limit and see if it'll let you. Sounds to me like a clutch switch playing up.
  1. Wow, $4000.00
    By Finchy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2011, 05:15 PM
  2. [NSW] QLD/NSW WTB car $3500 - $4000
    By ratz26 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-02-2010, 01:27 PM
  3. 87 vl commodore $4000
    By dan_man31 in forum Parts And Other Items For Sale
    Last Post: 11-11-2005, 04:39 PM
