Results 1 to 10 of 10
Thread: vz trouble code in dash display
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Default vz trouble code in dash display
    hey people, i have an error logged on my dash when my car wont start. it wont start because i get the very low fuel error followed by the fuel gauge error, contact dealer. now, normally i have the trouble codes as follows
    0000000000000000
    1000000000000000
    however, when the car has its moments, it logs another one such as
    0000000000000000
    1000000000100000
    this code disapears once the car comes good and starts again. anyone know what this extra one is? also noticed that the temp gauge doesnt work, and in the menu, it says its 215 degrees and 0 fuel, both gauges show on the empty and cold mark.
    when i did get the car started, it shows 84 degrees and 30L respectively.
    so, any idea from the techs
    Spoken by a true member of The Committee
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i had the same problem once or twice rich, turned out to be low fuel, pup some fuel in, shorted out the starter and away we go. I remember talking to holden and them saying that the car could have some form of protection in that if the lines are dry and the car thinks it has no fuel, it wont allow you to start, throwing up this fuel guage error. I've also heard rumour that it could be the fuel pump on the blink or perhaps a problem with the fuel float.
    Each time it has happened to me i have come home from being away, the car has been parked on a slight angle and i have left the car with the Low fuel or sometimes very low fuel alert.
    Life starts at 200km/h
    May 2009
    Gold Coast
    Maybe so, but doesn't explain why all my needles don't work and my coolant says 215 degrees. I'm guessing an ecu or bcm prob or something getting mixed up.
    May 2009
    Gold Coast
    Car is always parked flat, and the car comes good after it has cooled down a bit. I've never had the need to short the relay as the car will start after sitting for a few minutes
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    my needles were doing the same. if you are still having troubles get it scanned, that is the only way to be sure. Mine only did this when it was low fuel and sat there for ages.
    VZ Wagon
    Jan 2012
    Meadow Heights Vic
    Default Hi All
    I have the same error code as you listed on top ( the 1 to the left). Did you end up finding out that the issue was?
    May 2009
    Gold Coast
    i think its normal for the first lot, with the 1 on the left. my prob with the other one seems to be connected to an ecu problem
    VZ Executive
    Oct 2011
    with out knowing what the error code means from the symptoms you described in the first post have you considered the sender unit. My car would occasionally give a very low fuel warning if i drove with less than a third of a tank sometimes but after a few minutes of driving it would return to where it was.
    Last time i got it serviced my mechanic said he re programmed the fuel gauge system, dont know if thats right or not but what ever he did it hasn't happened again since and ive had a lot of tanks through it
    May 2009
    Gold Coast
    yea, i have considered that, but then whats the go with the coolant temp? they are obviously not directly related
    VZ Executive
    Oct 2011
    you are 100% correct and after reading your post again PROPERLY this time i see where i went wrong...............i only read the first part
  1. Problem with dash lcd display.
    By axemurderer101 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-10-2011, 06:57 PM
  2. Dash display for CD player
    By nkidney in forum Car Audio
    Last Post: 23-03-2010, 10:06 PM
  3. VY Stereo Display Flashing? Wrong Security Code?
    By Swift in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-10-2009, 02:23 PM
  4. VY Dash display stopwatch
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-05-2006, 07:34 PM
  5. Dash stereo display in Vy
    By RAZZA in forum Car Audio
    Last Post: 09-02-2006, 07:44 PM
