Results 1 to 2 of 2
Thread: Broken Seat Belt Buckle
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Broken Seat Belt Buckle
    As the title suggests, the drivers belt buckle, the bit that the seat belt clips into has broken and wont lock the seat belt in place.
    Do the earlier model commodores have the same setup? or do i need to replace with the same model. I can pick up one easily from a wreckers for a VT/VX. The only difference i could think of is the eletrical warning to remind you to put the seat belt on, would this not being connected also cause a fault code?
    Life starts at 200km/h
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Probably same model as the pretensioners are part of the buckle assembly.
    Silver Certified.
  1. Seat belt buckle removal (VT) - QUERY
    By awhite_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2010, 03:27 PM
  2. rear middle seat belt bottom half way up seat
    By michua in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-09-2008, 08:20 PM
  3. rear seat belt guide broken (station wagon)
    By Ian J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2008, 08:48 PM
  4. It all started with a broken timing belt
    By Simion in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2006, 12:25 PM
  5. scrolling belt buckle
    By _Mukas_ in forum The Pub
    Last Post: 10-06-2006, 06:56 PM
