Results 1 to 7 of 7
Thread: What psi in air shocks
    vz wagon
    Jan 2012
    blue mountains
    Question What psi in air shocks
    Gday
    I have a holden fitted 2100 towbar with air shocks. Can someone tell me what pressure - preferably in psi they should have. The valve indicates 400kPa to 1030kpa - does this seem very high.
    Thanks
    VT HSV Senator Signature
    Jul 2009
    vz wagon
    Jan 2012
    blue mountains
    Thanks - I have worked out the conversion - but 58 -149 seems high - can someone verify this. I am about to put a new caravan on next week much heavier than my old van which died.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Unfrotunately"ispeed" is correct crappy air shocks do run on pretty high pressures.
    MONROE SHOCKS & STRUTS :: Max-AirŪ Air Adjustable Shocks :: Air Adjustable Shocks
    My Senator had the factory self levelling suspension (fancy words for automatic air shocks) which I replaced with Koni adjustable shocks and air assist bags inside the springs, much better handling and can still carry loads, just have to manually pump up the bags but as they only take 30psi max can pump them up with a bike pump which I carry in the boot.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    vs commodore
    Oct 2009
    Tamworth NSW
    The gregorys workshop manual says that the superlift shocks should not be pumped up any higher than 1034 kPa (150 PSI). It also says to never drive the car with less pressure than 103 kPa (15 PSI) in them..
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    vz wagon
    Jan 2012
    blue mountains
    Quote Originally Posted by Torquative View Post
    Call me stupid but where's the valve ?
    The valve is attached to 2 very small hoses that are put through a hole in the back of the wagon beside the towbar.
  1. Replies: 4
    Last Post: 22-11-2010, 09:15 PM
  2. VU Ute Rear Shocks Bouncy (NEW Shocks)
    By shadowmaster in forum General
    Last Post: 06-10-2010, 05:46 PM
  3. [SA] F.S. KYB shocks & Pedder Sports Ryder shocks
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 16-03-2009, 04:43 PM
  4. FE2 Gas Shocks
    By Murmur77 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 06:27 PM
Tags for this Thread
