Results 1 to 6 of 6
Thread: wont start and doing my head in!
    vz
    Jan 2012
    heywood
    Angry wont start and doing my head in!
    hey guys i have an 04 belina lost my licece left the car sit for a few months started it drove fine then parked it again went to start it the next day turn the key nothing dash came up fuel gadge problem contact dealer and showed the gadge to be empty with 0 kms (had 3/4 a tank) fuel gadge was faulty so i replaced the sender anyways still nothing pump wont evan prime up.. have gone over battry voltage was good tested all realays and fuses all ok done earths pulled bcm fuse to reset the codes no codes in the car but still wont read the fuel gadge or start has got me a bit stumped just wondering if its happend to anyone else and if so what the cause was
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Did you plug the new sender unit when you replaced it?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    WL CAPRICE
    Mar 2011
    My mate has a Vy Berlina and the same thing happend to him two days ago but it happened after he filled up his petrol tank with safeway crappy 91 Unleded.
    Still trying to figure out whats going on.
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Does no one read older threads? There are a few recent threads about this issue, including my own thread, and it turns out to be a corrupt ecu
    Spoken by a true member of The Committee
    VZ alloytec Calais
    Oct 2009
    Port Macquarie
    There are a number of threads on here about this problem and the same thing happened to two mates. What it turned out to be in the end is the bottom of the ignition barrel was shorting.... There's a plug or switch etc at the bottom of it........ and it was shorting the ECU and BCM etc..... See if you can get it started by bridging out the starter relay. In my mates car it would then run normally for a few days or even weeks before it did it again. It would throw the fuel gauge error and not turn over.
    vz
    Jan 2012
    heywood
    yeah mate all pluged in iv been through the older fourms but seams to be diff symptoms to them but i will try that thanks mate
LinkBacks (?)
  1. 14-02-2012, 08:52 PM
  1. vt wont start after head gasket change
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2011, 02:07 AM
  2. New Key now car wont start and cuts out when km's on cluster start flashing :(
    By rowiejoan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2011, 10:44 PM
  3. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  4. replaced head gasket but wont start
    By redrags in forum The Pub
    Last Post: 24-12-2010, 08:50 PM
  5. car wont start after installing head unit!?
    By vs calais 95 in forum Car Audio
    Last Post: 12-08-2009, 09:46 AM
