Results 1 to 7 of 7
Thread: one tonner tray lowering
    vz tonner
    Aug 2010
    adelaide hills
    Default one tonner tray lowering
    a few quick questions regarding lowering my ute.
    firstly im lowering it to make it easier to load the motorbike on the back if it makes any difference. i also do tow a horse float with this car so i dont want anything that will make doing that more difficult.
    first up. lowering blocks? whats the go with these, are they legal? and do they make any difference to the suspension other than height?
    also will old school, hq, wb sized lowering blocks fit or are they a wider spring etc?
    second. lowering the tray to the chassis, can you buy lowered supports for it? or will it be a case of cutting and shutting all the factory supports? will there be any side effects from doing this?
    CRUSTIN is offline P-plater
    VZ S 175 Ute
    Nov 2010
    Also look up if people have had an issue with driveline angles when lowered. Its ok for the style side because it uses donuts for universals, im not sure if the 1 tonner has the same, i assume not.
    Originally Posted by Little Red VZ Go-Kart
    1. Why would you want to floor it, or move it to the red line? Especially with the lack of airbags and ABS features!? What do you hope to achieve by that??
    Originally Posted by HoldenV8
    give everything a spray with wd40 wheels brakes that should fix the squeaks
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    Lowering with leaf springs -
    doggy - flip the load leaf, and remove one small leaf totally - shit ride - illegal
    Block's - They can start to put your diff on a bad angel if you go beyond 3inch - so i have herd
    Lower leaf springs - same as a lowered coil in a car
    standard spring reset - same as in compressing coil's
    Shocks same as a car in the way if you go XXXXXX lower then stock your gona need them..
    hope that helps a little..
    vz tonner
    Aug 2010
    adelaide hills
    okay, so whos had any experience with these? whats the biggest blocks i can go before i get into trouble with drive shaft angles etc.
    vz tonner
    Aug 2010
    adelaide hills
    also with blocks, what needs to be done with the brake bias valve? i have heard that something may need to be extended/ shortened and where would i find this control arm?
    vz tonner
    Aug 2010
    adelaide hills
    please some one help out haha. after getting my self some lowering blocks from auto barn, coming home to fit and finding out i have ford one, going back. getting the ' holden' ones and attempting to fit these and not working.
    can someone tell me what sized locator holes the speings have? i have misplaced my veneers and the best i can do is with a tape measure, which is roughly 15-16mm. now i dont want a rough guess cos i know ill end up getting the wrong sized locators again. so can someone with some knowledge help out
    vz tonner
    Aug 2010
    adelaide hills
    http://www.nolathane.com.au/bulletins/Update%20504.pdf
    good info for anyone needing to know what size they need
  1. VZ 1 tonner tray back ute. 2005
    By jandg in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2011, 05:35 PM
  2. Vz awd tonner
    By vztonner in forum General
    Last Post: 24-07-2011, 11:15 PM
  3. vy one tonner
    By reef166 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2011, 01:29 AM
