hey guys, i did have 4x 20cm LED strips in my tub and 1 in each footwell all wired into interior light right at the interior light, all worked fine for months until i noticedone 1 side of my tub lights werent working traced wires and insulation had melted on one set of wiring, noticd smoke, pulled interior lights fuse and turned of interior light yet light remained on even with no fuse and switch turned off. i disconnected all LEDs so now is bak to factory lighting yet now interior light and ignition barrel do not light up. bulb seems fine, fuse is fine an relay seems fine yet neither intrior light or ignition barrel will turn on. any ideas plzzzzz help.
Impluse blue SVZ
LoweredExhaust and hardcover to come
i had a similer problem with mine, my interior light would have constant power would never turn off even when i took out the fuse it still stayed on, had it looked at and was told the BCM shit itself. $1500 from holden to change but got it at $600 from my local auto electricion
