Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By RiCeY
Thread: Question: Possible to convert Fog Lamps to DRL?
    VZ Commodore SV6
    Jan 2010
    Adelaide, SA
    Default Question: Possible to convert Fog Lamps to DRL?
    So I've got the VZ SV6 which has those lovely fog lamps I'm not allowed to use ever because I don't live in the hills and never get caught in fog. I've been reading on the legalities, and the DRLs are legal because they are 21W or something, whereas the brighter 55W fog lamps are illegal to drive unless it's actually foggy.
    Whatever.
    Question is: is it possible to just change the globe in my fog lamps to a much dimmer globe which complies with the law?
    (I am aware that I can buy LED strips, and I'm looking into this too, probably going to order some in the next 10 minutes - but I'm curious because I'd like to be able to use my fog lights legally as DRLs also.)
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Just use your foggies man, youd have to have the worst luck to get busted with them on, i have 8000k hid foggies (blue) and drive with them on all day, cops drive past and nothing ever happens...
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Why use fog lights when theres no fog, its retarded and the cops will eventually fine you. Putting HIDs in the foglights is even more retarded as they will be absolutely useless in fog.
    Silver Certified.
    05' VZ Exec
    Jul 2009
    Quote Originally Posted by RiCeY View Post
    Amen, just make them look good, you don't have to use them :P
    VZ SV6 2005
    Jan 2012
    i was thinking of just putting a blue LED in mine purely for show and no gain because ive been in fog at my joint once i think in 5 years.
    ive been asking around about all types of exterior lights and cant get a straight answer, anyone here know the laws for WA??
    i wanna run some exterior LED's behind the number plate on my VZ shining down onto the lower grille. but dont wanna get pinged for it.
    Willo
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Any colour not white or yellow front facing forget unless u don't care paying money to a copper to tell u they're illegal.
    If u wanna put say a white led in there, check eBay to see if there is something to directly replace the type of globe u have, say h4 or whatever the size/type is on the vz fog loom
    Ghost's Avatar
    Sep 2011
    Ricey I'm not sure how Hids could be useless in fog as I was running full headlight Hids in a previous car and the beams were so bright they were cutting through the fog and I could see everything in front of me
    VZ Custom 3.6L Alloytec, VS Ute 3.8L Ecotec
    Nov 2008
    Darwin
    first off the fog lights are down low for a reason. they shine along the top of the road. noone is gonna give a shit how bright they are cause they wont be shinning on other cars anyway they are supposed to be adjusted so they shine straight ahead at the level of the fog lights. its only illegal if your stupid enough to adjust them up to shine onto other cars and alot of new cars have HID fog lights standard and those led strips that come with the new VE HSVs and the Audi's are brighter than most normal fog lights anyway. so long story short you have nothing to worry about. the only light that has any restrictions on brightness is your everyday low beam headlight
    Nov 2008
    Darwin
    Willo just do it anyway and put them on a switch so you can turn them off when driving in the street and turn them on whenever you want. thats what i did in my VZ
    Quote Originally Posted by DylanWillo View Post
    Willo
    VZ SV6 2005
    Jan 2012
    Sweet, cheers man. might just do it and if i get done ide be very unlucky but atleast ill know haha
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by heathsydm View Post
    I cant see HIDS cutting through fog, more likely reflecting off it rendering them useless. Fog lights are a different light to normal and HID.
    Silver Certified.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Just a heads up, a fog light is designed to illuminate the road markings from underneath the fog, as fog sits just off the ground. In no way are they designed to cut through the fog or illuminate anything else.
  15. #15
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Unless you get something in the low kelvin range. Mine are 3000k and they're awesome.
  16. #16
    Ghost's Avatar
    Sep 2011
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Torquative View Post
    My point is that installing HIDs into foglights results in a much broader and brighter beam which will do nothing but reflect straight back off the fog.
    Brighter isnt better when youre talking foglights.
    Silver Certified.
  18. #18
    Torquative's Avatar
    Jun 2005
    And I'm agreeing with you. My post was in reference to the earlier HID post but i cnt work out how to quote on the phone
  19. #19
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  20. #20
    VZ Commodore SV6
    Jan 2010
    Adelaide, SA
    No worries - I'll double check to ensure that the bloke I bought it off hasn't adjusted the foggies up. I'm thinking of switching the globes to white just to match the white LEDs I've ordered.
    Thanks guys!
  1. [QLD] Fog lamps
    By paynetrainvy in forum Parts And Other Items For Sale
    Last Post: 24-11-2010, 06:47 PM
  2. fog lamps
    By Macka21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2009, 08:20 AM
  3. fog lamps
    By Anton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2008, 10:16 PM
  4. VT/VX fog lamps
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2006, 10:18 PM
  5. Fog Lamps. Need Help
    By mat vsII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2006, 07:23 AM
Tags for this Thread
