Results 1 to 14 of 14
Thread: Vz 6.0l engine ticking
    SS Thunder 06
    Dec 2011
    perth
    Default Vz 6.0l engine ticking
    my 6Lt in my ute ticks on idle and gets much louder on acceleration and once acceleration is taken off the noise quietens any help ?
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Change your oil - Using castrol mine used to tick like a clock, now that I've changed to Nulon it seems to have stopped it.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    SS Thunder 06
    Dec 2011
    perth
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Lifters would be the cause of that?
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by one_and_only2004 View Post
    I'm using Castrol Edge Sport 10W60, it ticks for about 5 seconds on start up and then disappears. It was worse when my old mechanic was using Oleon.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Oil pump may be on its way out so youre not getting pressure to the top of the engine so lifters etc will be noisy.
    Id get an oil pressure test done.
    Silver Certified.
    vyss
    Jan 2012
    adelaide
    VZ SV6
    May 2011
    Baulkham Hills
    In my old celica the oil levels got real low (yeh a real stupid thing to have happen) and it turned out that it messed up the bottom end bearings. Had to get them replaced....lucky i didn't do any more damage than that
    vz Executive
    Aug 2011
    BF BEND
    Quote Originally Posted by VZSSTHUNDER06 View Post
    go to the ve site, plenty on there about lifter issues in v8.
    what we have here,is a failure too communicate!!
    SS Thunder 06
    Dec 2011
    perth
    VZ SS
    Jan 2011
    vz 6L L76,s are bad for lifter tickin. Most of them do it at some point. Even mine on cold starts
    I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
    Sep 2008
    I had the same problem and changed to Penrite HPR 5 5W-40 and problem solved
    VZ Maloo
    Feb 2012
    Kalgoorlie WA
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I had a tick and a slight pinging (could hardly hear it until it was up into high rpm and under load) and no one could figure it out, so I went from a 5w30 to a 15w50 until the engine dropped to 2 bars and wouldn't change. So I changed the lifters and and still had the same issue, so I decided to do the oil pump and it turned out the timing chain tensioner had broken up and blocked the oil pickup. Must have been a year that I was trying to find the issue before it lost oil pressure.
    E1 GTS Timing chain tensioner!!!!
  1. Ticking Sound From The Engine
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2012, 09:26 AM
  2. Vy ticking engine
    By r8-762 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2010, 08:17 PM
  3. ticking engine
    By r8-762 in forum General Discussion
    Last Post: 28-12-2009, 12:14 PM
  4. Engine ticking
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-08-2009, 08:41 PM
  5. Engine ticking
    Last Post: 26-07-2009, 01:09 PM
