Results 1 to 21 of 21
Like Tree4Likes
  • 1 Post By dijm8
  • 1 Post By Jesterarts
  • 1 Post By dijm8
  • 1 Post By Kernal
Thread: vz rpm limit? dodgy tuner? tuning question
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    Default vz rpm limit? dodgy tuner? tuning question
    To anybody that knows a bit about tuning the alloytecs, i have a question.
    i have a VZ 190kw sv6 manual, have had it dyno tuned, along with a host of other mods, have run a 14.9 before, so i know it's healthy.
    I took it in to a tuner to have the RPM limit upped from 6700 to 7000. which i don't think is a huge ask, ive seen videos and instances of alloytecs revving that hitgh without too much of a problem.
    the tuner called me not long after i dropped it off and said that it was already set at 7000, the engine just wouldnt get there... and then tried to tell me it was stretched timing chain and because its a tired old motor etc...
    Now, i admit the motor has done 260,000 Kays (alot)... but the coils, plugs, injectors, intake manifold (cpr6), exhaust, 20%underdrive, and a host of other things are less than 20,000 kays old, i did an overhaul not long ago. and as i said, the motor is still as healthy as anything, it's run a 14.9 not long ago and still goes MUCH quicker than standard. It doesn't blow any smoke or anything either.
    And i know when i hit the 6700 limit, its still pulling hard, it just hits a brick wall. it doesn't gradually slow down or feel like a drop in power, it just dies as soon as it hits 6700, the same as it did when i bought it standard 150,000 kays ago...
    So, anybody that is knowledgable in tuning and these motors, is the tuner pulling my leg, or could it actually just be suddenly stopping at 6700 because of parts? There are no sounds from the engine or codes for timing chain wear, is there possibly a parameter in the computer that the tuner hasn't set properly?
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    dijm8's Avatar
    dijm8 is online now What You Looking At
    VZ SS LS3
    Jun 2006
    those things you've replaced isnt making any difference, like the tuner said it could be the internals that needs changing, has the timing chain been replaced in the last 150k ? otherwise i would be looking to do that
    now i knw SFA about v6's but really but are you expecting? throw in some diff gears if u wanna pull harder otherwise save ur cash for when your off ur P's and get a v8
    Dz811's Avatar
    VZ SV6 M6
    Sep 2009
    No the timing chain hasnt been replaced, but regardless there are no rattles or error codes which indicate stretching.
    And i wasn't saying the things i replced were going to make a difference, but they definitely wouldnt be causing it.
    The idea im getting at is there's no reason why it shouldnt be able to rev higher than standard, especially since it's still more than healthy. And that all signs point to the rev limiter still being there even though he says it isnt.
    please dont give me the "go buy a v8", that's got nothing to do with what im asking.
    I know these motors quite well, ive pulled a couple apart and worked on many, my family alone has 2 (my brother has a wagon with the 175). That's specifically why I asked for information from an expert.
    if you know "SFA" about the v6's then please leave my question to people who know more than me. Not having a go at you, there's plenty of motors i know nothing about, but i know these backwards.
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    So what are you trying to achieve by upping the limiter in a 250k old motor?!
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
    Dz811's Avatar
    VZ SV6 M6
    Sep 2009
    Quote Originally Posted by ParkwayDrv View Post
    it would bring benefits on the 400m times, because 1st and second gear are much shorter ratios in the manual than the autos, and would be lucky if it spends a grand total of 3-5 seconds there over the course of its entire life.
    The internals (valves and valvesprings, cams etc.) are more than capable of running at that limit.
    (its only 300rpm higher than stock ffs, there's alloytecs revving higher than that out there)
    again, what does this have to do with my original question?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    250+k engine
    aftermarket modifications putting more strain on internals.....seems pretty str8 forward to me
    I'd be doing the chain.
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    VZ SV6 2005
    Jan 2012
    Ide go with timing chain considering what everyone here is saying, and also agree with the other guy about saving for a V8 although this is alot that goes into putting one in.
    do u know how many km's these other SV6's have done? mine just hit 120,000 and ive never hit the limiter but if your always doing it everything in the motor is getting thrashed and stretched, stock internals arnt really built for racing i dont think
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    you guys are all fkn stupid, answering un asked questions and stating things that have NOTHING to do with what he asksed, YES it can rev to 7000 and YES ur tuner is full of it, think about it the timing chain wouldnt make it impossible to rev to 7000 itd just be very sluggish up at those revs. take it to someone else
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by vn_v6 View Post
    Well, obviously it can't otherwise we wouldn't be reading this thread now would we?
    I thought that was fairly obvious.
    I'm also impressed that you can make such statements without seeing, driving, hearing or working on this particular car.
    I also suggest you do some reading in regards to timing chains as a stretched/worn chain can affect a cars ability to rev higher. A stretched chain could be causing a timing issue at higher RPM and just lack of power.
    In direct response to the OP. If the tuner said the chain is stretched then why would you have reason to doubt him? And I will agree that considering the engine has been around the block a few times it could be causing it to not rev as high as you want.
    If you don't trust him, then go elsewhere but without seeing the car you can't get a definative answer on here. Maybe the engine limiter is set at 7000rpm but some sort of any abuse software is kicking.
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    My limiter was set to 7k when i got my VCM tune done. It revs to 7k with absolute ease and my timing chain rattles quite bad.
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Does anyone know if they make stronger chains like a double row or similar for cam upgrade and other mods
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Quote Originally Posted by Dz811 View Post
    soo you know these engines backwards? so why dont you knw the problem then?
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    For starters, how does the tuner know the timing chain is stretched without pulling it apart and if it doesn't make any rattles? 2nd, my car is still set on standard limiter and hits 7000rpm, so I dunno, might be a tuning incapable thing.
    Spoken by a true member of The Committee
    VZ SV6 2005
    Jan 2012
  15. #15
    Jan 2008
    NSW
    Just think to yourself. . . What can you possibly get from increasing the limiter by 300rpm on whats supposed to be a 6cyl family car apart from the potential to #### up your motor.
  16. #16
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by Kernal View Post
    Sicker mang mang factor?
  17. #17
    Jan 2008
    NSW
  18. #18
    May 2009
    Gold Coast
    well the alloytec produces its peak hp at its limit, 6500, so increasing to 7000, if its within the engines limit would also create a higher hp, my guess anyways. doesnt the cpr6 manifolds ute rev to 9000rpm with only head work? i think it still has stock bottom end, but i could be wrong. best thing for the op would to give phil a call from performance manifolds, he knows his stuff with the alloytec, so he would be able to give you some good straight out answers.
  19. #19
    Phantom vz sv6
    Sep 2011
    Just curious, what maximum speed the car will reach in each gear at the rev limit in the vz sv6 a5 with factory tune and standard diff ratio (I'm not ballsy enough to test it myself haha)
  20. #20
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by richardpalinkas View Post
    lots of work all over the car... the engine has had extensive work done to it
    Life starts at 200km/h
  21. #21
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    he has reworded his website, but i remember it mentioning engine work
  1. Where? Best LPG GAS tuner / tuning in Melbourne??
    By CAPRILICIOUS WL in forum Tuning
    Last Post: 03-02-2012, 07:36 PM
  2. Replies: 42
    Last Post: 29-01-2010, 03:14 AM
  3. Alloytec Tuning Question
    By impulsive in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-08-2009, 01:11 PM
  4. Is this possible??? (Tuning Question)
    By vagure5 in forum V6 Development And Modification
    Last Post: 08-10-2007, 09:09 PM
  5. EFI tuning basics question
    By blofly in forum General Discussion
    Last Post: 05-09-2005, 05:06 PM
