Results 1 to 12 of 12
Thread: ABS brake failure
    vz s ute
    May 2011
    adelaide
    Default ABS brake failure
    this post has been deleted
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    If you were riding the brakes previous, it may be brake fade, of I've also heard if the handbrake is adjusted too tight, it created excessive heat which can cause brake fade also. Brake fade is where the pads create a gas between the pad and rotor, meaning there is no friction to cause you to stop, slow down. I would get the pads replaced and machine rotors with good quality pads like bendix ultimate
    Spoken by a true member of The Committee
    04' VZ SV6
    Sep 2011
    Rinwood North, Melboure, Victoria
    I had the same thing happen New years day. Merging into traffic the car infront of me slammed on breaks as did I at about 10-15km and the car did nothing but lock up and shutter at the same speed straight into the ass of the car infront. I've brought my problem down to Warped rotors. Bought brand newies and pads to change over once car gets back from shop. If anyone has any other solutions would love to hear them also as my old 1986 4Runner would of stopped within that distance at the speed no problem!
    You drive a FORD? That's O.K we all make mistakes..
    04' VZ SV6
    Sep 2011
    If you find the Rotors are warped and would rather change them all over plus the 8 new pads I asked around all over Ebay and got this deal sorted and cheapest by $100:
    This sale is for a Full Vehicle set (4 disc rotors, 2 front, 2 rear) of Gold Zinc, Dimple Drilled and Slotted Front and Rear disc brake rotors and Front and Rear Bendix GCT Pad sets to suit Holden Commodores with standard brakes, models VT, VU, VY, VX, VZ, V6 and V8, including all Omega, Calais, SV6, SS Sedan Ute and Wagon and also Statesman WH, WK, and WL models and are a direct replacement item.
    The Disc rotors are genuine RDA items (Rotors & Drums Australia) and the rotors fit like the original factory items.
    If your interested PM me and ill send you in the right direction.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    I would be paying a bit more for my brakes as they are the only thing stopping me!!
    My opinion is get the best pads you can get and also some slotted rotors, while your at it get braided lines as well (although there not really needed).
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    04' VZ SV6
    Sep 2011
    Lol they didn't cost $100 it was the cheapest deal by $100
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If your tyres and suspension are flogged out the tyres were probably skipping on and off the road causing the abs to keep pulling braking force away to try and regain traction. Much like trying to stop a 4wd with ABS on sand, it wont stop at all.
    Brake fade I doubt unless you had just been beating up on the brakes, warped rotors wont stop the brakes working either. Failed master cylinder would stay failed, not come good again.
    Silver Certified.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    ABS doesnt work by stopping braking altogether. Take it to someone that isnt an idiot.
    Silver Certified.
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by thecougar View Post
    Haha whoops.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    When you brake hard the brakes will pulse on and off quickly rather than just locking up. The car should still pull up very quickly.
    Silver Certified.
    vx
    Aug 2011
    sa
    abs is designed to pulse your brakes so you still can steer around obstacles( people), with locked up brakes you have no steering ability,
    ,,nothing wrong with the car but the operator,too close/day dreaming.. slighty warped discs will still stop all day,, but when apllying the brakes the sterring wheel will shudder.. brake fade??? maybe but only when youve been using the brakes for heavy towing.. master cylinder if ####ed will stay ####ed,, so your answer too this question ,, operator ereor,,, part off life ... just be gratefull no kids where hurt in this life lesson. and yes i hate people who ride up my arse, normally see them shit when you turn your tail lights on, that wakes the ####ers up
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    now now ladies, finz, if you were too close like you stated, then i dont think it was any braking component. im sure 99% of people have been too close once in there life, you just paid the price. No one hurt, except pride. All good!
    Life starts at 200km/h
  1. Brake pad failure
    By Trevhead62 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-09-2010, 10:35 AM
  2. possible brake failure?
    By Static89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2009, 10:18 AM
  3. Brake failure wtf :)?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2009, 10:01 AM
  4. Brake Light Failure
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2006, 07:28 PM
  5. Brake failure
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 12:18 PM
