Results 1 to 5 of 5
Thread: vz stalls turning to the right
    BANNED
    Feb 2010
    Default vz stalls turning to the right
    Our vz every now and then just stalls when turning right ,?All services up tp date and checked over no issues to be found??Anyone have a similar issue ever?happened 3 times now...
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Have you recently had a new fuel pump fitted?
    A bloke at work had an aftermarket one fitted in his VZ and if he has under half a tank of fuel, it stalls, also only when turning right.
    If you havn't had a new one fitted, then there may be something stopping the fuel from getting into the little 'tank' that surrounds the pump.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VZ SV6 2005
    Jan 2012
    well if all the fuel is on one side then no fuel goes to the engine, then it stalls
    BANNED
    Feb 2010
    Quote Originally Posted by RiCeY View Post
    Does it matter how much fuel is in the tank?
    Nope just does it at random times?????
  1. VT stalls when turning right.
    By Gokz777 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2011, 08:04 AM
  2. 00 VX Commodore -fault code 0012 normal operation -car still stalls turning right
    By janelle in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2011, 09:25 AM
  3. VT Executive 98 3.8L V6 stalls/cuts out when turning corners
    Last Post: 19-12-2009, 12:01 PM
  4. need help asap v6 stalls turning right only
    By calais_8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2009, 02:22 PM
  5. VR stalls when turning hard right..help??
    By poonmobile in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2008, 08:00 PM
