Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Jesterarts
Thread: 18" wont fit!
    VZ executive
    Jan 2012
    Werribee
    Default 18" wont fit!
    Hey guys, I recently bought new rims for my VZ. Went to get some tires put on and they said that because the rims on my car are 15" I have to get the speedo
    timed or something like that. They said the max I can go is 17" and the rims I got are 18". Has anyone had this problem before?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    any rims that are more/less than 2 inchs in diameter will have an effect on your speedo
    but it should be sweet F A difference
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I went from 16's on my VY to 19's and my speedo was 100% dead on. You can get it checked on a dyno usually for $100.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    or you can check on a GPS, it will give you a rough idea at least
    VZ executive
    Jan 2012
    Werribee
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Holden can recalibrate it for you to suit what ever size wheels you put on, or someone handy with a tech 2 or similar.
    Phreddy did mine on my old VY, had 15's on it and I put 20's on it - 5% increase in speed, they just change the PPM (pulses per minute).
    VZ SV6 2005
    Jan 2012
    VZ Executive
    Oct 2011
    ive got 18's and the tyres on them are 235x40 and my speedo isnt out, not noticeably anyway
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    VZ executive
    Jan 2012
    Werribee
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    You're in vic so the only tyre/wheel laws are:
    MAX of 25mm increase in width, max of 15mm increase in overall rolling diameter when talking going UP in size.
    Both these are also from values from the LARGEST wheel/tyre the manufacturer specifies for that vehicle.
    In a nutshell, you can fit 18's without any legal issues as long as the correct width and overall diamater tyre is fitted.
    If a tyre place tells you otherwise, go somewhere else as they don't know what they are talking about and I wouldn't trust them near your car.
    Good luck with it mate.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    235/45x17 and 235/40x18 tyres have the exact same outside diameter so the tyre guy doesn't even know his own products very well and both are the sizes that Holden fitted to pre VE cars when fitting either 17's or 18's.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. VR Gearbox Issue - Wont drive in "D"
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 11:00 AM
  3. WM Statesman - "Contact Dealer" and "X Service" and Empty fuel gauge issues
    By selimlok in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-11-2010, 07:15 AM
  4. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  5. front left wheel wont stop squeaking "making the car sound VERY crap!"
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 05:48 PM
