Results 1 to 8 of 8
Thread: Have I screwed up? Noise in front of motor...
    2005 VZ SV6 Commodore
    Jan 2012
    Toronto, NSW
    Exclamation Have I screwed up? Noise in front of motor...
    Hi, I have a 2005 Sv6 Commodore 5 speed auto
    I have recently (within the last week) modified the intake to allow more air to enter the airbox, buy just removing the intake pipe that curves upwards and replacing it with a cold air intake shroud off of the monaro.
    I replaced the air filter with a K & N panel filter.
    Yesterday I was advised to clean my airflow sensor and told to spray it onto the outer and inner components of my airflow sensor.
    I then left the sensor unplugged to dry as I was not driving the car that day.
    This afternoon I plugged the sensor back in and started the car up. It sounded really odd when it started up and was a little rough on idle. I then gave it a little throttle and noticed a knocking noise at the front of the motor every time I hit the accelerator. The car seems fine to drive and is alot more responsive but I am VERY concerned about this noise which I believe is in the intake manifold. Is this a normal thing when the car is adjusting itself to the new air levels or have I stuffed the sensor by spraying it? By the way I did NOT bridge any wiring with the spray.
    Thanks,
    Reece
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Jan 2012
    Toronto, NSW
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Did you tighten up all the clamps that you may have loosened?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Jan 2012
    Toronto, NSW
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    i doubt the cleaning of your maf and knock are related. and if there is something in your intake manifold then remove the manifold and shake it out
    Life starts at 200km/h
    Jan 2012
    Toronto, NSW
    Thanks mate, will give it a go when I get the chance. The knock happened directly after I cleaned the maf, so I wasn't going to rule it out.
    To be honest, it does sound like theres something in there but what is the question.
  1. Strange Ratcheting/clunking noise similar to CV noise under front VE 2009
    By Velocity in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-08-2011, 05:04 PM
  2. FRONT WHEEL Brake NOISE - me and my mechanic cant find source of noise. help???????
    By northqueenslandvs97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2010, 08:36 PM
  3. Screeching noise rear of motor/ front of tramsmission
    By raubrey149 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2009, 11:28 AM
  4. clicking noise front of motor VN
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-12-2005, 08:56 PM
  5. Noise from front of motor
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 11:34 PM
