Results 1 to 22 of 22
Thread: Asking for help from middle east
    vz
    Feb 2012
    Dubai UAE
    Smile Asking for help from middle east
    hey guys
    i have chevy lumina ltz which is commodore vz
    the engine alloytec v6 done 190 ks
    The problem is when hard accelerate the car hesitate but after 3000 rpm goes fast and smooth (i mean full throtle from zero) and when crusing at 90 km/h i increase accelerator little misfire come but if i push more accelerator and trans kick down every thing become fine .
    what i am feeling the car not geting enough fuel under 3000 rpm i dont know the reson
    I change fuel filter , spark plugs changed 130 ks , i check for intake leaks every thing fine.
    i take the car to dealer the said every thing is fine just need tune up( spark plug ,coils , fuel filter , intake gas kit )
    I am not Convinced to change all these part (i think AFR problem)
    so what you say?
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    vz
    Feb 2012
    Dubai UAE
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    VZ Executive
    Oct 2011
    i know they are on the exhaust but where are the cats located, if some one could post a pic of what one looks like that would be awesome.
    And i assume to check for blockages you just unbolt and clean? What would you use to clean them with?
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    Quote Originally Posted by aaronevolution View Post
    Check your exhaust/cats for blockages?
    Wouldnt something come up on the computer at the dealer if it was blocked up?
    Quote Originally Posted by ra3i ss View Post
    What is Flux capacitor ?
    Flux capacitor is trolling for no aparent reason.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Coils on these things are notorious for failing aren't they?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Yeah probably something minor like the dealer says, but he's just geussing and changeing everything to find the one thing thats causing problems. Could just be 1 coil not 6.
    Could be the transmission fluid needs flushing too. That can cause ruff feelings lowdown.
    VE SS Sportwagon
    Feb 2010
    Brisbane - Southside
    COuld also be plug leads breaking down under load. Cheap thing to replace anyway.
    Luke V8's Avatar
    VE Commodore SSV
    Feb 2011
    Quote Originally Posted by Pickle' View Post
    Ahh pickles .. First time I've been accused of being a troll lol
    Sorry all - seemed funny last night - really must remember not to login after a few beers
    Mar 2008
    Quote Originally Posted by mummbles View Post
    pretty sure these things don't have spark plug leads.
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    When I had a blocked cat last year, it took 2 weeks before the warning light came on.
    Jan 2008
    NSW
    Quote Originally Posted by Luke V8 View Post
    I've said it before ... I'll say it again...
    2 words my friend..
    Flux capacitor
    Dont pay any attention to this guy, I think he may be on the piss lol. Flux Capacitor is a component in the car in which Marty and Doc used to travel back and forth through time.
    If i read that correctly you changed them at 130 and now the car is at 190?
    Dude thats 60000ks without a proper service.
    A mate of mine had the same problem. Just give it a full service and it should fix the problem.
    Phantom vz sv6
    Sep 2011
    Maybe new battery or alternator upgrade to provide the 1.21 jiggawatts for the flux capacitor
  15. #15
    vz
    Feb 2012
    Dubai UAE
    Thank you to all
    I am going to check
    1- Cats(in our country we only have one O2 sensor every side befor the cats not like yours bank1 and bank2) so if blocked will not appeare code
    2- Transmision flush (it could be because the transmision cooler craked in 150 kms and water got in transmision )
    3-spark plugs i will change it any way
  16. #16
    njmartin is offline Banned
    VR exec, VY wagz
    Nov 2011
    S.E Melb
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    Any pics of your car ? any mods.
    Originally Posted by 87RB30VL
    Huh? I got given the gun of my neighbour,
  18. #18
    VY S V6 Ute Series II 2004
    Nov 2009
    so what you say?
    A blocked or dirty fuel injector would cause those symptoms. You could try running some fuel system cleaner through a tank of fuel (you might be lucky) but best to have them removed and professionally cleaned.
  19. #19
    vz
    Feb 2012
    Dubai UAE
    Quote Originally Posted by CLUBSPORT#325 View Post
    Am working in offshor company (sea survey) i am far away from my car after 10 day going back and will post some pic
  20. #20
    vz
    Feb 2012
    Dubai UAE
    Quote Originally Posted by SavVYute View Post
    Already try fuel cleaner nothing change at all
    thank you bro
  21. #21
    Nov 2009
    thank you bro
    The fuel cleaner only works sometimes... most of the time its a waste of money. Even "on car injector cleaning" is hit and miss because it flushes the rubbish from the fuel rail and lines through the injectors and can make the problem worse..
    I put up with a sick car for months until I finally pulled the injectors and had them properly cleaned off the car. Made it run like new.
    A new air filter could help also if you have dusty conditions over there.
  22. #22
    VY ute (2003)
    Jun 2010
    Manly
    I must admit i had a chuckle when he asked what it was... Good troll good troll
  1. 2003 Monaro - Middle East
    By K0M0D0 in forum VT - VX - VU - WH - V2
    Last Post: 01-03-2011, 04:37 PM
  2. Getting a car from the East to WA
    By anonymousmoose in forum The Pub
    Last Post: 02-09-2010, 12:15 PM
  3. Holden VX (middle east)
    By ahmedomnnea in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2010, 04:25 AM
  4. middle exhaust
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 11:54 PM
  5. 2001 Commodore VX (Middle East Edition) a.k.a Lumina
    By sherwin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2006, 09:40 PM
