Hey guys,
I went to get a wheel alignment and balance and they found that one has split the inner wall completely, so i bought some vy stockies thinking i could just throw them on and be on my way but they dont fit!
the studs all match up but the wheel wont sit flush on the hub and i have no idea why?
any help is very much appreciated, ive had this car for just over a month
Well then they are not from a vy. They all share same stud pattern and center hub size.
ill double check the hub size, pretty sure everything did fit but it wasnt flush
Check there's not a hub spacer stuck on your hub or in the rim
cheers man ill go check that, i was running 20's before which were the same size all round so maybe.
if they fit on just keep tightening the wheelnuts till it sits flush, she'll be right
Yeah there was some collars i didnt see, took them off and put them back in my 20's and now its all good.
Cheers for the help guys
