Results 1 to 6 of 6
Thread: L76 cam
    VZ SS
    Jan 2011
    Default L76 cam
    Here is a link for a cam i want to put in my VZ SS 06. Would anyone be able to tell me for sure that it has everything i need for a L76 engine? (http://www.precisionintl.com/online/...x?CID=41223219). It needs to be suited for boost. (Is high lift good for that?), Is it true the l76 has L92 heads? Does it have a 3 bolt cam? Also has anyone got a video of a car with a cam like this one??
    VZ SS
    Jan 2011
    Need to no if my standed push rods will work with this cam? Have ordered the cam. Can anyone tell me if i need new push rods?????
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    link goes to site but no cam info
    pretty sure L76 is single bolt and you will want new pushrods but best to measure once cam is in
    EASY $30 DIY Cold Air Induction!
    Quote Originally Posted by stuffedifiknow View Post
    would this mod work like forced induction.
    VZ SS
    Jan 2011
    http://www.precisionintl.com/online/...x?CID=42357834. Hopefully this works better. Is there anyway you can tell me with the specs so i can order the parts before i pull the engine down?? Also I got a 3 bolt cam but can always change cam gear of its wrong.
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Usually you look for lift of a cam when talking NA engines but with boost the air is compressed so its not as necessary. But you say you've ordered this I would be talking to an engine builder or someone more in the know as I don't think it would be suitable for boost but I could be wrong
    Also yes the L76 run the square port L92 heads
    I think you may need to run a VVT delete kit to run an aftermarket cam aswell
    VZ SS
    Jan 2011
    yer iv ordered the dod delete kit with the cam. All duration numbers, valve lift numbers and revs for the cam are the same so should be good for boost i hope. For the push rods guess ill just have to check when it starts going back together, if there going to be the right length. cheers for the help
