How to pull off? I found two clip things in the rear but I can't push it out?
Sent from my iPhone using Tapatalk
Flatblade screwdriver covered with a rag and carefully lever it off, thats how I did mine and no damage done.
Silver Certified.
Fishing line and saw away behind the badge to cut the glue/ foam. Never put a screwdriver near paint, runs too much risk of accidentally scratching through the rag, personal experience
I heard heat gun/hair dryer to soften the glue the fishing line or string.
No need to be scared of screwdrivers like Richard over there, its impossible to accidentally scratch the paint when youre levering away from the paintwork. Rag on the corner of the boot at the leverage point and a rag around the blade end and lever outwards. If you slip the blade flicks away from the paint. Sawing at it works but leaves twice as much double sided tape behind and takes twice as long.
Silver Certified.
+1 for the fishing line then simply wipe off stuck tape with wax & grease remover and then polish the area. Took me all of 10 minutes to do 2 badges on my boot.
Cheers guys heaps of help.will be removing my badge this arv ready for the Cadillac badge.
