Results 1 to 4 of 4
Thread: VZ sv6 alternator problem, Lost all charge while driving
    VZ SV6 manual
    Dec 2006
    Default VZ sv6 alternator problem, Lost all charge while driving
    hey guys,
    so yesterday i had a random check alternator warning come up on the screen. after doing some research here i followed the diagnostics screen and found the voltage at the time to be around 14v. think i hovered around 13.7-13.9 with lights stereo on.
    driving home from work this morning, lights and stereo on, i got the check warning again, followed by my ABS faulting out and airbags faulting out, shortly followed by me losing all my dash power (speedo, fuel etc) then the car died, tried to restart but got the dreaded click click click.
    ive been reading on here about charging issues, from what ive seen the VZ alternator doesnt have a regulator that can be changed and is controlled by the PCM?
    so basically just after some ideas where i should be looking, either alt or PCM computer issues.
    VZ Executive - Clubsport Conversion
    Jun 2009
    Castle Hill, Sydney
    i had a similar problem about a month ago, and it turned out to be just a loose rusted main ground wire which had almost come off the chassis. the vz alternator is electronically regulated and i have never heard of a problem with it. did you try jump starting it off a healthy car to see if that makes a difference? it could be a fauly alternator
    HSV Clubsport VZ Body Conversion - Mace CAI - 2.5" Walker Single Catback - Red Neons - Custom Dash
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Make sure the battery terminals are clean and tight then as said check leads to/from Alternator.
    Around 14v is a good charge rate how old is the battery?
    Silver Certified.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    the vz alternator is internally regulated, ve's have the computer controlled alt's
    jump start it with another battery, it is possible for a cell to colapse or short out in a battery making it go flat so to speak, if you jump it and check the charge rate (13.8 to 14.4) and seems fine, replace the battery, if you jump it and its not charging, i.e idle battery voltage anywhere from 11.8 to 12.6 volts, get the alt checked out
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. alternator kicking in and out of charge
    By 17TUX in forum Electrical Wiring / Questions
    Last Post: 05-02-2012, 08:37 AM
  2. Good Alternator not supplying charge
    By 4Runner conversion in forum Electrical Wiring / Questions
    Last Post: 23-02-2011, 02:55 PM
  3. Almost lost power when driving
    By [Linkin Park] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2009, 04:50 PM
  4. Alternator charge rate VN/p 85A?
    By NOGEN 3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2007, 09:40 PM
  5. alternator charge
    By spherical in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2005, 01:53 PM
